Question about Radio Communications
I have a DCSPHFS -GN-US-4 and the pilot wouldn't come on.
Posted by Dunz Cain on
How to set timing 99 evolution 1340 cc
Hi Mason, I borrowed this from a Harley Davidson Tech Forum.
"•set piston in front cylinder at TDC on compression stroke center vertical line in timing hole
•turn ignition on make sure run switch is on
•using volt meter, measure voltage between GN/W wire from sensor plate and ground while rotating sensor plate to do that, follow wires from sensor plate to ignition module connector back-probe the GN/W wire at connector (it may be GN wire instead of GN/W on your bike)
•when voltage changes from 0 V to 4-5 V (or vice versa), stop, set sensor plate
•it's now timed at TDC at 0 RPM
It may be easiest to access the green or green/white wire (depending upon model/year) at the connector at the ignition module, not the connector from the sensor plate (between the ignition module and the sensor plate). Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 08, 2015 | Harley Davidson Motorcycles
Need driver for getnet 150 gn-531u
i want the driver for the pilote getnet150
Nov 05, 2011 | Computers & Internet
How to make a GN 9350 unit work with Windows 7?
Skip dealing with it. You don't need the $110 BS "upgrade" as this is a driver issue. Jabra could very well have provided a downloadable and install-able driver for the GN 9350 that would work perfectly, and tell windows not to use the unsigned USB driver in the headset firmware.
Fortunately there is a quick-fix workaround... it is only a little bit of a pain (and proof that their $110 firmware upgrade is not necessary).
When you want to use the jabra with Win7:
1. Plug it into your computer via USB.
2. Go to your playback devices menu (right-click the speaker icon in the system-tray)
3. Set the GN 9350 as the default device for recording and playback.
(right-click, and test, should error (couln't play test tone)
4. unplug the power to the reciever/base.
5. wait 10 seconds.
6. plug it back in.
7. may need to set it as the default again, but you should be good for a while, just don't switch back and forth too much between computer and phone.
Oct 03, 2011 | GN Netcom GN 9350 Wireless Headset
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
Turned down the fireplace accidently turned it off. The pilot can be pushed in however it is not igniting . Can it be lit manually
If your getting a flame when igniting, and your still pressing in on the pilot then all you need to do is hold it in for about 30 seconds or so. This is because theres a thermal cutout then needs to heat up form the pilot to keep the flame lit.
If you've got no flame at all then you should look at your fireplace manual and see if theres an alternative to lighting the pilot. I wouldn't recommend opening it to light the pilot.
Apr 17, 2011 | Heating & Cooling
I'm hooking up my sony player to a nissan versa and the colors are confusing and I'm tryna get it to work , and it wont
Car Colors (Assuming NON-Rockford factory system)
4-6 speaker system.
Accessory 12 Volt L.GN
Constant 12 Volt BN
Chassis Ground BODY
Power Antenna
Remote
Illumination OG
Dimmer (-) Bk
Left Front Spkr + WT
Left Front Spkr - BN (PK @ Spkr)
Right Front Spkr + GN
Right Front Spkr - L.BU (RD @ Spkr)
Left Rear Spkr + VT (L.GN @ Spkr)
Left Rear Spkr - RD (GY @ Spkr)
Right Rear Spkr + L.GN
Right Rear Spkr - GY
CLICK HERE for generic wiring tips for your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | Sony XPLOD CDX-GT200 CD Player
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
Radio Communications Logo
124 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
