Question about Altec Lansing Audio Players & Recorders
I dont know how to replace the charging port on the Altec lansing speaker
5 Suggested Answers
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
Anonymous
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
Anonymous
  • 10 Answers
SOURCE: Altec Lansing ATP3 volume control/power know gone bad
just sone it, i had to break a whole in the bottom part , work my way around it with a screwdriver , it will snap every 2-3 cm and come off in the end.
after its off start at the (now exposed) bottom of the front bit and work your way up and aroud `till it comes off. mind the wires . as for the volume button fix , as soon as i played with it and tried it again , everything was good. even though replacing it doesn`t seem like a big deal
put it back together and will superglue it in the future( while typing this i doubt if it will ever happen), and it lookes good( except from the bottom ,where its broken !).
now the button is solid and the sound as well.
SWEET
SWEET
Posted on Nov 05, 2009
Alan Peterman
  • 7 Answers
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
How do change battery in altec lansing speaker.altec lansing speaker is not working
I have one also and I am fairly certain the battery can't be replaced. Once it dies you have to replace the speaker.
Jun 06, 2018 | Altec Lansing Audio Players & Recorders
I had ordered an altec lansing 1220 speakers from flipkart. While i plugged in the speakers there was no power input to the system....hence it didn't work...when I checked on altec lansing website it...
This speaker is using a USB to draw its power. You can try using other USB ports on the computer or use USB chargers (Apple, HTC, Android phones, etc) to test it, if all else fail then you may need to return it because its defective.
Aug 27, 2011 | Altec Lansing BXR1220 2 Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
Need driver for Altec Lansing 221 Operating Sys Vista
The independent site providing the software is not working anymore, and the 221 are not anymore in factory product page. I think the best thing to do is contacting directly Altec Lansing, and asking a replacement cd.
Regards
Apr 06, 2008 | Altec Lansing 221 Computer Speakers
Finding replacement Power Supply for Altec Lansing
Hi Yeo...
Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model.
I hope this was helpful.
enjoy
Feb 20, 2008 | Altec Lansing Multimedia Computer Speakers
Altec lansing vs4121
u dont need any driver to play the speakers, yes the sound card does, take down ur sound card modle no. and try looking in www.driversguide.com let me know.
Feb 12, 2008 | Altec Lansing VS4121 Speaker
How to repair atp3 altec lansing
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
Altec VS4221 not working with Gateway
I am guessing that the speakers our connected to the input port.. make sure it not plug on the input port...
Jun 16, 2007 | Altec Lansing VS4121 2.1 Channel Powered...
49 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
