Question about Radio Communications
My Baofeng UV-82HP transmits but doesnt receive on VHF channel 63a. I work with Lifeguards on public beach that use that channel to communicate
Posted by D Driscoll on
Kristyanna Virgona
    New Friend:
  • 28 Answers
You need to program the correct frequency. the Marine Channel 63A is 156.175Mhz. they also maybe using a PL Tone or a CTCSS tone, you have to find out what it is. using the Chirp Programing software you can do that. but remember sometimes a Cities use a non standard CTCSS tone so you can only hear each other
Posted on Oct 03, 2019
5 Related Answers
MikeNJ1964
Mike Longo
  • 398 Answers
SOURCE: reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Posted on Sep 01, 2007
eradiostore
eradiostore
  • 1664 Answers
SOURCE: my customer has 6 motorola max trac vhf radios.
If this is a new install, it is likely noise from the vehicles electrical system scrambling the processor of the radio. Put a filter on the power leads and check your install.
Posted on Aug 31, 2009
Anonymous
SOURCE: Navman VHF 7100 Radio neither receiving nor transmitting
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
Posted on Apr 02, 2010
Lisa Burrow
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
had the same problem...took out nimh...replaced with triple A...works great!!
Thank you!!
Posted on Oct 13, 2011
Norm Pearl
  • 108 Answers
SOURCE: I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Posted on Sep 14, 2012
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
Aug 06, 2014 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Help me put frequency in baofeng uv-5r
CHIRP (Chinese Radio Programming) software is available free online. Also, search for "MIKLOR". They have great manuals for Baofeng UV5R manual online.
Mar 15, 2014 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Dec 14, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Will not transmit to a repeater
1) are you within range,?
2) is there an obstruction between you and the repeater?
3) do you have the proper PL tome programmed for the repeater?
4) When you press transmit, is the correct input frequency displayed?
Nov 29, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
My baofeng uv-5r will not transmit any solutions?
Don't know what software you used but try looking up a program called Chirp on the internet and use it to progran the radio. The program gets updated a lot. It has worked well for a large group of us. Is the battery fully charged?
Oct 15, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Baofeng uv-5r will not transmit
Sounds like you have the transmit lockout set. this radio is a bit of a pain to program, but is well worth the effort. your best bet is save your settings (backup) and do a full factory reset, and start over, making sure you did not lock out the transmit on any channel or VFO...
Oct 15, 2013 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Radio will not transmitt
In the software, there is a transmit inhibit feature. Also, if you try to program some frequencies outside what the radio is allowed to do, they will receive only. This is a Ham radio, not a business band radio. You cannot legally program business frequencies on it from 01/01/2013. It is not US FCC type accepted.
Aug 06, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Need to program baofeng uv 5r
That is outside the 140-174 range of the radio. It cannot be programmed in this radio.
Apr 13, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Radio Communications Logo
172 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
