Question about Jabra Radio Communications
How do I change batteries in my Jabra hfs 100
Posted by Tom Dabner on
Jabra strom is not charging
https://www.jabra.com/supportpages/jabra-storm#/#100-93070000-02
Online chat available now with manufacturer web site, or can put in a form with your question.
https://www.jabra.com/ServiceMenu/contact/ContactJabraSupport/ContactJabraSupportConsumer
Jul 13, 2018 | Jabra Radio Communications
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Jabra bt530 does not hold charge
    Did it used the charge before?
    How long do you have it for?
    How often is it required that you change your battery?
    Is your charger really connected to the power socket?
    Does it show a charging light?
    Feb 11, 2014 | Jabra BT530 Bt HDst Black Bluetooth...
    Jabra wave battery suddenly won't charge
    The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
    Jan 13, 2014 | Jabra Wave Bluetooth Headset
    Jabra BT2080 - been working well, charges and shows green charged light but bluetooth doesn't light up and unit shuts off.
    This problem is mostly associated with the battery of your device. In some cases, the battery is most likely to have expended it's lifespan.
    In this case, all you need to do is to change the battery. It is advised that you get a professional to change the battery for you as trying to do this yourself could lead to a damage in the device.
    Apr 23, 2011 | Jabra BT2080 Bluetooth Headset
    Jabra 5050
    Sounds like you've used this thing quite a bit, eh? Rechargeable batteries only last for so many charges. If a charge doesn't last very long anymore, you probably need to change the battery. This is not for the technically challenged. The battery may just pop out of a slide cover, or may require practically breaking the device in half to get it open, then unsoldering the old battery and resoldering a new battery in place.
    But, it definitely sounds like you need to replace the battery. You may have to consider a new one - sorry.
    Apr 21, 2010 | Jabra SP100 Bluetooth Wireless Adapter
    My jabra bt 160 wont work after a long time of not using it, and how to pair it to a device?
    Your battery may be completely discharged. contact Jabra to fix this problem. Jabra has a lot of problems with their batteries!
    Feb 22, 2010 | Jabra BT125 Headset
    I charged the BT350 using the Jabra Charging
    I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
    Thank you,
    Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
    I need help changing the screen on a sony ericsson C905
    I don't quite understand...
    Do you mean changing the wallpaper?
    Sep 15, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
    I lost my instructions to my Jabra bluetooth and can't remeber how to install on my chocolate phone by verizon
    try holding down the "on" button on the jabra 'til you get a solid blue light that stays lit. Then go to connection/or bluetooth on your phone and follow the path to find or search for devices.
    Regards,
    Lonnie
    Mar 31, 2008 | Jabra BT350 Bluetooth Headset Headset
    Radio Communications Logo
    128 people viewed this question
    Top Jabra Radio Communications Experts
    Anthony Ward
    Anthony Ward
    Mosaub Al Masri
    Mosaub Al Masri
    Ekse
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
