I have a bose companion 2 speaker set. I plugged in an AUX from my headphones & it broke now the tip of the cable is stuck inside the speaker The speakers detect headphones so they wont play music
How can i fix this
Posted by Cheni X on
5 Related Answers
Anonymous
  • 32 Answers
SOURCE: Speakers do not work
yes thats the fact when you plug a headphone into any speakers the head phone will be the only one to function the speaker stops thta the circuit technically which will break the connection of power to speaker if you plug head phone
Posted on Apr 20, 2007
Richard Roberts
  • 198 Answers
SOURCE: Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Posted on Mar 10, 2008
Anonymous
  • 168 Answers
SOURCE: Bose desktop speakers stopped working suddenly
Make sure that the power is plugged into both the wall or strip and the back of the speaker.
Posted on Jul 17, 2009
GFXTech
  • 73 Answers
SOURCE: Samsung TV and Bose Campanion 3 speakers
Are these PC speakers? OF so you need a stereo RCA to min-jack cable, assuming the TV has a set of RCA audio outputs.
Posted on Jul 26, 2009
Anonymous
SOURCE: Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Posted on Nov 18, 2010
Can i connect my bose companion 2 speaker to my 42pg3000 plasma tv
yes audio out of your plasma tv use cable bose companion 2 Audio Input Cable with RCA plugs and try
May 20, 2012 | LG 42LG50 42 in. LCD HDTV
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
Jul 25, 2009 | Bose Companion 2 Computer Speakers
Not working on my hp
make sure there turned on or make sure it`s in the right AUX input
Apr 13, 2009 | Bose Companion 2 Series II Multimedia...
Bose Companion 3. Speakers are very faint in sound. The touch pad seem inoperable. (the green light on pad does not come on.)
Check first that you have connected the speaker to the right output. For example on many computer there is an aux output marked in blue that can give you this problem.
If the problem does not depend from the source, then that sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
Mar 05, 2009 | Bose Companion 3 Computer Speakers
Dec 26, 2008 | Bose Companion III Computer Speakers
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
Left speaker sometines has no sound? Please help
I bought a set of Bose companion 3 speakers and the darn RCA jacks are cheap and wiggling loose. The cost to send back and repair out of warranty is about $125!! BOSE companion speakers may sound good, but for my money, I'd rather go with more reliable computer speaker systems like Creative or Logitech. BOSE IS WAY TO OVER-RATED, but HEY....they suckered ME out of $275!!!
Feb 06, 2008 | Bose Companion III Computer Speakers
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
