Hey Mr. Ireland,
Buy it online or for example at Walmart. https://www.walmart.com/ip/Reusable-Disc-for-Tassimo-T-Disc-Brewers/969171195?wmlspartner=wlpa&selectedSellerId=6601&adid=22222222227068550690&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=174507050630&wl4=pla-279834610029&wl5=9011912&wl6=&wl7=&wl8=&wl9=p
SOURCE: lights keep flashing on my tassimo machine
if your lights are flashing on your mashine just keep your finger on the button untill its filter threw, willtake up to 2 mins. simon bernasconi
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
SOURCE: PROBLEMS WITH THE BRAUN TASSIMO MACHINE AND T-DISCS
Drop kick the damn thing in the ocean! This machine is crazy! It spits boiling hot water and coffee grinds at you...
SOURCE: brewed coffee goong into used grounds holder
HI
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Testimonial: "nailed it! Now I just need a new thumbscrew"
