Question about Westinghouse Televison & Video
Westinghouse WE55UDT108 turns on then freezes at logo screen at least a full minute then turns off tv. Pressing power on the remote after the tv turns off, will usually start it normally
Franco Dosil
    Top Expert:
  • Westinghouse Master
  • 10,535 Answers
Hello, for what you know, your Westinghouse WE55UDT108, would need a firmware update, look at www.westinghouse.com for the updates available for your model and the downloads in an empty USB memory, without any file and then put it on the TV
Hola, por lo que cuentas, tu Westinghouse WE55UDT108, estaria necesitando una actualizacion del Firmware, busca en www.westinghouse.com las actualizaciones disponibles para tu modelo y la descargas en una memoria USB vacia, sin ningun archivo y luego la colocas en el TV y actualizas el Firmware
https://www.techwalla.com/articles/how-to-update-a-westinghouse-lcd-tv
https://usermanual.wiki/KUNSHAN-KONKA-ELECTRONICS/WE55UDT108.15-WE55UDT108-UserMan-part2/html
https://fccid.io/2AHAK-WE55UDT108/User-Manual/15-WE55UDT108-UserMan-part2-3568058
Posted on Jun 19, 2019
Testimonial: "the links you give go to a sales page for tvs. There is no link for a firmware download and I get no answer from Westinghouse emails. Very frustrated as this tv is only 1.5 years old"
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: When I am trying to turn on the tv by remote or pushing the power buttton it goes to stand by mode
Solder bad connections vertical output IC......requires chassis
to be pulled....................T.
Posted on Dec 06, 2007
Anonymous
SOURCE: White Westinghouse 32 in Issue
hey u wanna sell the lcd screen let me now 916-613-3009 albert
Posted on May 27, 2009
Anonymous
  • 9 Answers
SOURCE: No power on Westinghouse sk-19h21os flat screen monitor tv
I found a 2200microfarad @ 10v capacitor in the switching power supply that was bad. In these supplies, precision is crucial and tiny changes in the circuit will make them fail. Good luck !
Posted on Jul 25, 2009
Anonymous
  • 3 Answers
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
Posted on Jun 12, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I have a Westinghouse W3223 TV which has decided
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 25, 2010
Testimonial: "Thanks very much! That seems to have worked."
Used universal remote still have sound on tv but lost picture
follow this instruction and fix it. God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Aug 01, 2013 | Westinghouse 16093 Remote Control
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
I have a Westinghouse W3223 TV which has decided not to turn on any more. It powers up just fine as always. But instead of showing the video input source before showing the picture, now it shows nothing...
Jun 25, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
White Westinghouse flat screenTV freezes up and hums.
Sometimes if you just press on your overscan button on the remote and make the picture a little bigger or smaller the humming noise and freezing of the picture will actually stop.
Jul 27, 2009 | Westinghouse SK-26H240S Television
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
229 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
