Intel D945GCNL Motherboard Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio driver instalation
How to solve the audio driver error 0xe000227
Anonymous
Level 2:
  • Expert 102 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Answers
102
Questions
0
Helped
41796
Points
273
Here is a list of things to try:
Note: Start with #s: 6, 7, and 9
1. Uninstall and reinstall the sound drivers
2. Install K-lite codec pack http://fileforum.betanews.com/detail...d/1094057842/2
3. Start > Programs > K-Lite Codec Pack > Configuration > Codec Tweak Tool and check the box next to [Registry] Fix non-working system sound
4. Make sure the volumes are not set to zero and that nothing is on mute Control Panel > Sounds and Audio Devices > under Device Volume, click on Advanced
5. Make sure that everything in Device Manager is fine (no yellow or red marks) Control Panel > System > Hardware tab > Device Manager
6. fixnoflashsound.reg (just click on the link and install it) http://files.filefront.com/fixnoflas.../fileinfo.html
7. netvol.reg (use Internet Explorer to click on the link and install it) http://www.kellys-korner-xp.com/regs_edits/netvol.reg
8. If possible, make sure Digital Output Only is not check marked (not all cards support Digital Output Only) http://tomebling.home.comcast.net/~t...oundConfig.jpg
9. Confirmed the presence of msacm32.drv and msacm32.dll
Search for these files in C:\Windows\System32
If you don’t have it, download it from here:
http://www.filesavr.com/msacm32
Made sure speakers are properly connected to sound card
Run SFC /Scannow
Start Menu > Run > type this in exactly (note the space between C and /): SFC /Scannow
Tried different Video player
Installed Quicktime Alternative
Reinstalled DirectX
Confirmed presence of "plug and play software device Enumerator"
Made sure that default devices were selected
Control Panel > Sounds and Audio Devices > Audio tab
Tried using different settings in the sound card’s configuration window
Installed Microsoft ADPCM Audio Codec and IMA ADPCM Audio Codec
for %x in (C:\WINDOWS\System32\*.dll) do regsvr32 /s %x
Thanks
6helpful
2answers
I have a intel DG31PR motherboard, when i am trying to install audio drivers an error appears " Driver failed to install (ERROR : 0xE0000227) " Please give me a solution to install the driver.
Hi, please try this solution;
  • Open Device Manager (Start> Control Panel> System> Hardware>Device Manager)
  • Click "View" on the toolbar and select "Devices by connection":
  • Disable and uninstall by right clicking on "Bus Driver for Microsoft UAA High Definition Audio"
  • You can now install the drivers normally and without error
  • Kind Regards
    Audio driver install to error for microsoft bus driver HD install
    hey download the bus driver first . u can get it from microsofts website i too did the same but i have forgotten the link. sorry find the driver and first install driver for the BUS. then install the audio driver
    2answers
    Problem with audio driver
    check your BIOS if the souncard is enabled.
    install the chipset driver first
    then install the sound driver.
    be sure you are installing drivers for XP not Vista
    29helpful
    2answers
    Realtek hd audio driver failure
    right click my computer > manage > device manager > system devices > microsoft uaa drive .. disable and uninstall..
    find hardware
    or
    install the software ,,, '
    restart.
    1helpful
    2answers
    Microsoft bus driver
    I am having HP pavilion dv6915ee laptop. I have installed windows Xp and installed all device driver except sound driver. When I try to install it It is asking to install the microsoft bus driver before installing audio device. Please anybody help me to fix it.
    41helpful
    8answers
    Need Sound Card Driver (Compaq Presario C700)
    hi firend
    here is link
    Audio driver from the link below .
    Conexant CX20549-12 High Definition Audio driver:
    ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
    Do not click on the link. Please copy the link and paste the link at the
    address bar of the browser. Next hit the enter key.
    k
    Installing this driver may result in an error. But continue with the
    following steps to get the audio driver installed correctly.
    1. Click on Start and select Run. Now type devmgmt.msc and press enter.
    2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant
    High
    defination audio entry and click Update driver.
    3. Select "Install from a list or specific location"
    4. Click Next. Then select "Don't search, I will choose the driver to
    install"
    5. Click Next and then select "Sound, video and game controller" from
    the
    list.
    6. Click Next and then click Have Disk.
    7. Click Browse C:\swsetup\sp35940 folder and the double click the
    (WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file,
    click open and Continue with the onscreen instructions.
    Similarly install Modem Driver:
    7helpful
    3answers
    Unable to install Audio driver
    Have you installed the chipset drivers first?
    2answers
    Audio Driver of Presario C700 can not install
    i have to install sound driver.
    Compaq.
    Model No. - Presaroi c700
    Email- [email protected]
    3answers
    No audio driver
    This issue could be caused by any of the below possibilities.
    1. Bad software settings.
    2. Corrupt or missing sound drivers.
    3. Compatibility issues with the operating system and/or other hardware.
    4. Speaker related issues.
    5. Bad or missing sound card.
    Top Intel Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
