Question about Sewing Machines
Service manual for B&K MODEL 1471 ocilloscope.
Posted by James DuPuy on
The flywhee on my pfaff 1471 seems to have disengaged after unsuccessfully winding a bobbin. The motor goes but the needle does not go. What to do?
Did you turn the knob inside the hand wheel backwards while holding the wheel itself? If that knob is in the correct position, did you hear it snap into place when you rotated the hand wheel towards yourself? Does the needle bar move up and down when you rotate the hand wheel?
I suspect that the needle bar is still disengaged from the motor mechanism. The manual is available from Pfaff on the creative 1471 page: http://www.pfaff.com/en-US/Machines/creative-1471 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative1471-manual-EN.pdf . See page 13 of the PDF for the picture of the direction and position of the knob that should be checked.
If the machine still doesn't work, it may be that the belt is bad. This connects the shaft of the motor to the mechanism that runs the needle bar. You can find a parts list for the 1471 here: https://www.universalsewing.com/tek9.asp?pg=parts_pfaff . Scroll down to find the various 1471 diagrams. The belts are probably available at most Pfaff or other sewing machine dealers. This page, https://www.sewingpartsonline.com/pfaff-1471-sewing-machine-parts.aspx , is one source. You want the motor belt.
I hope this helps.
Apr 07, 2018 | PfaFF Sewing Machines
Pfaff 1471 threading instructions
Hello Patricia P. Thomas
Download a free Pfaff 1471 Manual here
https://www.manualowl.com/m/Pfaff/creative-1471/Manual/333543
The threading instructions are quite simple to follow.
Please let me know how this works out for you.
Happy Stitching
Feb 27, 2017 | PfaFF Sewing Machines
Pfaff 1471 frozen. Button lights on, nothing works; frozen.
UNPLUG it from the wall wait a few minutes and plug it back in .if this does not work contact Pfaff tech support
Sep 15, 2015 | PfaFF Sewing Machines
I just retrieved my Pfaff creative 1471 from a dealer in Annapolis where they were to have cleaned and tuned it up. It makes a strange sound in the shaft where the needle bar goes up and down and black...
I would assume these people being dealers and all, would know what they are doing, right?
My first reaction would be to just go back there before their warranty expires and have them correct this problem, which I suppose did not exist before they laid their mitts on your Pfaff 1471
Don't try to fix it yourself. You paid for the service and they must do it right.
Most important of all of all, don't continue using it bacause the problem will only get worse, and logically you will be the one they blame for it.
Feb 13, 2011 | Sewing Machines
What year was serial number 82848782 produced? Pfaff 1471
The 1471 first came out about the early 70's
Oct 27, 2009 | PfaFF Sewing Machines
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
