I have a Sharp 56DR650. With the tv plugged in I get a red light under power on the front that stays lit. When I hit the Power button on the side the light goes out and I get nothing, no sound or color. Previously I had that lovely humming that everyone is talking about, but now it will noy even turn on. I dont have the manual so I am not sure if there is an easy solution for this. Thanks...
Check the switch activated by removing the small panel pn the back of TV - there is a switch there, to check you hae to remove the larger lower back panel but it's just about 12 screws to take off. Then on the left of where the small panel would be is an on off switch. Flip that on and turn on the TV
I have the colorwheels in stock if you need it.
Email me at [email protected] or 561-795-2500
note color wheels are one piece motor and glass
Engine block(color wheel) needs replacing approx $650 total
I have exact same currently with my 56DR650. Did you get this fixed and what was the problem and how much for repair, thanks.
