Question about Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Sharp AL 1631 is flashing 1 L. What does that code mean and how do I solve it?
Posted by balihai52000 on
Andrew Houle
  • 125 Answers
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Posted on Aug 09, 2009
Anonymous
Posted on Aug 10, 2009
Tareq Bin Mostaq Mostaq
    President:
  • Sharp Master
  • 1,449 Answers
Dear sir
if your copier scaner is loked then it sound if it no sound then open your copier desktop glass and clean cloth all serface and scaner sensor close your destop glass
  1. fhitting complite
  2. power on
  3. machine is ready
  4. L1 signal is scaner position problen
Posted on Aug 19, 2009
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
I HAVE A SHARP AL 1631, IT SHOW ME A 4 CODE, HOW CAN I TO SOLVE THIS
their is no A4 code,if you mean H4 try to reset it by simulation 14
Dec 26, 2010 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Flashing L-1
When your copier scanner is locked.Then show L1
or sensor is dirty or scanner jam.
Solve: clean thoroughly then solve your problem.
Jan 22, 2010 | Sharp AL 1631 Copier
LED flashing an "L"
L1 Mean scanner problem.
Solve: If you lock scanner please unlock.
L4 Mean Main motor or any Gear slug.
Solve:Please check motor section in your copier any kinds of Gear was broken.
Jan 13, 2010 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp AL-1631
Fuser is not heating up. Normally a broken bulb.
Unless you can get hold of spares, call the engineer.
Feb 13, 2008 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
923 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
