Question about Whirlpool Refrigerators
Does my Whirlpool ED25DQ have a water filter to replace
The ice cubes are starting to look like they have dust in them, just a little brown/yellow but not ALL of them just about 2/3's
Posted by Lucille Knapp on
JP Meneide
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Master
  • 483 Answers
Hi Lucille,
NO This model does not have a water filter.You will need to complete disconnect the ice maker and clean it out. Then remove and flush the fill tube. If ice still appear dirty, you may to replace the water valve,the water tube and the ice maker too. I will link the parts needed and see the repair video on how to access them. https://www.appliancepartspros.com/whirlpool-whirlpool-icemaker-kit-4317943-ap2984633.html
https://www.appliancepartspros.com/whirlpool-tube-water-w10823511-ap5989588.html
/whirlpool-water-valve-4318046-ap3103466.html
Posted on Jun 19, 2019
5 Related Answers
Anonymous
SOURCE: whirlpool ice cube maker not functioning
Comment regarding catriver Aug 18 post: Shorting L&V caused valve to work I believe, at least I think I heard it operate, but shorting T&H did not cause gear to move. So does that indicste a different problem? Still no ice. JimB
Posted on Oct 05, 2007
Anonymous
  • 126 Answers
SOURCE: Black flakes, like mold in water dispenser
check your water reservoir lower part of refrig. section ( take out crispers)
Posted on Dec 14, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Posted on Feb 24, 2008
Anonymous
  • 31 Answers
SOURCE: Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Posted on Jan 07, 2009
jpr12
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Posted on Oct 14, 2009
Whirlpool side by side has low pressure with filter, works great without.
more than likely the saddle valve...the valve you or the plumber installed to tie into the water line and shut it off for filter install. it's getting clogged up. Turn it all the way off and on again 3 or 4 times this should clean out the little hole feeding thru the valve from the pipe.
hope this helps.
take a look here...pics of a saddle valve.
https://www.doityourself.com/forum/electric-large-kitchen-home-appliances/395295-ge-refrigerator-freezer-no-water-flow-ice-maker.html
Jan 25, 2018 | Whirlpool Refrigerators
My automatic ice maker has produced hollow cubes, foul tasting cubes and now they just made cubes with a green color in the middle. What's up?
Hollow cubes usually caused by lack of enough water during fill. My guess is green is mold buildup. Check house water supply to refrigerator. Sometimes the little shut off valves for the refrigerator block up and need cleaned or replaced. Once you get proper size cubes, if taste/ color problem persists they sell small in line filters you can add in the water line to the refrigerator.(about $25.)
Mar 12, 2015 | Whirlpool Refrigerators
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Jan 07, 2010 | Refrigerators
My Whirlpool side-by-side fridge is only making about 4 ice cubes every 12 hours. Any ideas on what maybe wrong?
I would suggest replaceing the water valve , behind the refrig , where the wall water line connects to , on the refrig , AND remove the front kick plate , and clean the coils on the bottom , of dust , lint pet hair , etc . If your ice maker cycles , at least 8 cubes at a time , should dump . If only 4 , then not enough water is going into the ice maker .
Dec 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Waterline Rattling AND DIRTY ICE CUBES
Sound like a clogged valve or a dirty water filter. Change the filter then try it. Good luck.
Nov 09, 2009 | Refrigerators
Whirlpool gold not making ice but water dispenses
Pour about 2/3 cup of water into ice maker . If it dumps the cubes , but doesn't refill with water , replace the water valve . If it doesn't dump the cubes , replace the ice maker , after making sure the coils under the front of refrig , are clean of dust , lint , pet hair , etc .
Sep 13, 2009 | Whirlpool Refrigerators
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Brownish yellow color in ice cubes, is this a filter problem?
Is it specks ? If so , then the coating from the ice mold is disintegrating . Replace the icemaker . If the water color is brownish yellow , then I would suggest Home Depot for a filter which mounts to the wall or under cabinet ( about 50-60.00 ) with removeable cartridges . Would not recommend filter where you cut the line and install on both ends (10.00) .
Jul 12, 2009 | Whirlpool GD2SHGX Refrigerator
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
211 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
