Question about Car Audio & Video
Need wireing diagrram kdc 255u - Car Audio & Video
Posted by Charles Stephens on
2 Related Answers
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: I need a wiring diagram so i can connect it to my 1997 ford taurus
Hello elkhartsmost,
You can view the wiring diagram here.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
It's a secured PDF file which you can look without saving a copy to your computer. If you wish to save a copy, you have to pay.
Hope this helps.
Posted on Apr 22, 2009
pamabell
  • 316 Answers
SOURCE: echo tgrimmer wjring
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Posted on Feb 18, 2012
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
I have a 2001 dodge ram 1500 bought a Kenwood KDC 255U I have power to it but I'm not getting any sound out of the speakers
Does your truck have an infinity sound system? If you do you have to hook up the amp turn on wire to have the amp turn on and power your speakers. Even if you dont check to see if those blue wires are connected.
Oct 21, 2014 | Car Audio & Video
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Clarion cz 500 wiring diagrram
The wiring diagrams are on pages 29 and 30 of the manual available from here.
Jan 16, 2013 | Car Audio & Video
Echo tgrimmer wjring
Feb 08, 2012 | Echo Garden
95 dodge caravan 3.0 no spark
Check your Auto shutdown relay (ADS), if it's bad that will kill the fuel pump and ignition system too. If the fuel pump is bad or a short in the wire the (ADS) will trigger also. See if you could pull any DTC codes from the PCM. http://www.allpar.com/fix/codes.html Good luck and keep me posted, be glad to help.
Jun 09, 2009 | 1995 Dodge Caravan
Hello elkhartsmost,
Hope this helps.
Apr 22, 2009 | Dual XD-7500 CD Player
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
