Question about LG Televison & Video
Trying to replace parts to my 50LF6100 LG Smart TV. Where do I begin to find out exactly what components needs to be replaced?
Posted by Lisa Marie on
  • b1jqxk44
    b1jqxk44 Jul 10, 2019
    Hi Lisa Marie, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the TV doing wrong? Most problems are the power board or the TV board.
5 Related Answers
Anonymous
  • 2961 Answers
SOURCE: Supplying and replacing a LCD screen
i have spoke in the past to LG service and to buy an LCD screen actually costs more than a new tv.
Posted on Aug 18, 2008
Anonymous
SOURCE: needing replacement remote control....
i solved the problem myself by going to place of purchase of tv who sold me a spare part. As i said i was very disappointed with the help i got off your site and just want a full refund as it was a waste of money
Posted on Nov 17, 2008
Anonymous
SOURCE: lg replacement parts
how much for replacement screen for a 50"plasma modle number 50pc56zd
Posted on Sep 02, 2009
Anonymous
  • 120 Answers
SOURCE: we need a replacement bulb for our westinghouse
Hello, you need what is called a LIPS board which is power/inverter board, in order to get price and availability please email [email protected], make sure to include model#, serial#, and TW#, all located on the back of the unit.
Posted on Jan 26, 2010
  • 18822 Answers
SOURCE: how do I replace SMART TV SCREEN MODEL NO : LG 55LM7600 55'' 3D 1080p Full HD LED LCD Smart TV
You cannot replace a screen that big. The manufacturers wont ship it to you. IT has to be done by an authorized service center.
Posted on Nov 21, 2014
What are the exact steps taken when programming an rca universal remote to a LG tv?
No one buys universal remotes these days, you buy a remote for the television you have! They are $20 and an exact copy of the original.
LG Remotes: TV, Smart TV and Magic Remote Controls ' LG ...
www.lg.com > ... > TV Audio Video Accessories
Shop Genuine Replacement Parts. Didn't see what you were looking for? Click below to shop for more genuine LG parts and accessories. Shop Replacement ...
https://www.oneforall-canada.ca/en-ca/universal-remotes/urc-1811-lg-tv-replacement-remote
https://www.google.com/search?q=programming+an+rca+universal+remote+to+a+LG+tv
Codes
LG 0134 0004 0050 0009 0005 0155 0132 0227 0338 0012 0057 0080 0156
I have a LG 47ln5700 smart tv. The screen goes black but the sound still works. I replaced the LED strips and the tv worked for about 4 hours and then the same thing happened. Any suggestions?
Bad power supply board can burn out those led strips. Recommend replacing both board and strips at same time. Lg 47LN5700 UH TV Parts
You can order most of the parts here.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
2answers
LG47LN5200 tv has no picture but has sound
instead of guessing and wasting money , why not take in in and have the problem properly diagnosed
when you find out exactly which board has the problem replace it otherwise it could be all the boards only to find that it is the screen itself and the money spent is more than a replacement unit
1helpful
No picture on tv but does have sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
How do I fix bad HDMI inputs on LG 55LM6400 Smart TV
You need to replace the main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
1helpful
LG smart 47ln5700 the screen will go black i still have sound but no picture i could make out the picture in some angles need help on what parts i should replace(picture with flashlight on it)
Hi Angela,
The backlight system of your TV has failed. Mostly it is the inverter part inside the TV which makes necessary power for the backlights fails. The power/inverter board needs to be repaired or replaced.
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Replacing Circuit Board Capacitor
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Televison & Video Logo
Ekse
