Question about Lands Phones
Hi, When I pick up my phone to make a call, there are three beeps. Can you please let me know how to fix it?
Posted by Sherrie Mazzocchi on
T Tatro
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 20 Answers
It sounds like a voice mail indicator thru the TECOM voice mail service. Can you call Telco and ask them if you have voice mail, then you can either set it up or cancel it.
Posted on Jun 19, 2019
When i dont pick up my messages the phone beeps like a busy signal i have a panasonic model # K X TG 5671 its after the message is over it beeps
Many of the telephones have a built in answering machine. The beeps are to let you know you have a message you have not picked up yet. This to help you not miss messages. Check your owners manual to see if you can turn off or mute the message warning tone.
Oct 05, 2014 | Lands Phones
Net10 customer service
ok i bought three net 10 phones because you are the only service that really picks up where i live. however when i called yesterday to activate the phone the person on the other line was saying my zip code will not have access. however when i try to explain this to him he just kept saying. my husband has net 10 so does my daught. can you please fix this
Jan 04, 2014 | Cell Phones
When loading Fifa 11, a message comes up " an error has occured (80030001) it will let me go no further. What should I do?
Hi.
As far as I know this error has something to do with the database being corrupt. You need to rebuild the database.
To do this you need to turn off the PS3 so you see the red light. Flick the switch on the back off then on, then hold down the start button untill you hear three beeps then let go. Do the same again and the third beep will be followed by another one straight after the third.
On the screen there should be some options to choose from. Pick number four (rebuild database) this should fix the problem.
Also make sure that the PS3 is fully up to date by checking for any updates.
If the problem persists then I would advise you to contact Sony.
Good luck.
Jun 09, 2011 | Video Game Consoles & Games
Hi. My motherboard (MB) M925 V7.3 gives 3 long
Here's everything you ever wanted to know about Power On Self Test codes:
<a href="http://www.computerhope.com/beep.htm">http://www.computerhope.com/beep.htm</a>
Your three long beeps indicate the absence of a peripheral device known as a keyboard or mouse or other input means as follows:
Three Long Beeps Keyboard / Keyboard card error. CH000304
Mar 26, 2009 | PC Chips (M925G) Motherboard
Human touch HTT 800 just beeping from back, not remote
Just had this problem with our HTT 800. Discovered it was the curled phone-like cord attached to the remote that had been chewed through by one of our dogs. Some electric tape fixed it right up. Still looking for a replacement. Anyone know where I can find one? A standard-size phone cord does not work with this, as it is too large.
Feb 27, 2009 | Interactive Health Ht 135 Massage Chair
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Phone dialing problem
I had to switch the spy prevention function (IPP) off
Jan 10, 2009 | Lands Phones
Voicemail
Hi nexy - the best I can do for now is a couple things snd nothing definitive. Usually when a cell is off it takes 2 to 3 three rings before it goes to voice mail. When its' on about 5 to 6. There's a real good chance these are at the discretion of your service provider. That's my best bet. I've included a link to your manual in case you don't have yours. Look at page 50 (i think) and it tells about voice mail settings. You can go in there and take a look but don't get your hopes up. If this answered your question PLEASE rate as fixed. If your going to rate helpful or otherwise please don't rate. I've had many cell phones and I think I answered your question. So please rate fixed or not at all. I'd appreciate it. Thanks much nexy. Call you provider!!
http://www.wirefly.com/resources/phone-manuals/pantech/Pantech_C300_Manual.pdf
Jeff
May 18, 2008 | Pantech C300 Cellular Phone
Innovage (1604007) Corded Phone
Here is the fix for that problem...
1st click the set button on the bottom left of the keypad. Press the "up" button (located to the right of the the keypad) until you get to option number 7 IPP. Click the set button again (so you can change the settings for that option) and press the down button to turn off the option. Click the set button one more time and finally press the delete button to get out of your settings mode. No More beep, beep, beep......
Hope This Helped--WICC-
Feb 07, 2008 | Innovage 1604007 Corded Phone
RCA 4 line phone
Hi Richman,
If you have more than one phone line which I assume that you do -if one party has not completely hung up the handset after putting someone on hold when you pick it up on your end you will hear that beeping noise that you are talking about. Have them pick back up the line while you are on it and replace the handset again on thier phone to disconnect completely.
I hope this helps (trial and error)
Thanks
Oct 04, 2007 | GE 29488GE2 Corded Phone
Lands Phones Logo
106 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
