Question about Hitachi Televison & Video
How to fix dc power supply in a hitachi worldspace digital receiver kh-ws1
Posted by Elias Manoa on
trissa lee kelley
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 27 Answers
You better look it up online or if you don't have internet find someone who does
Posted on Jun 19, 2019
1 Related Answer
Anonymous
SOURCE: Hitachi KH-WS1
http://www.nodevice.com/user_manual/hitachi/radio1/khws1/download.html
Posted on Mar 31, 2008
I own a hitachi tv model le55a6r9a which has no pic but when using flashlight trick I see the picture can someone tell me what would need fixed with a part number
Your issue is in the LED lamps or power supply, test the voltage at the connector that comes out of the power board and see if you have voltage there of 100 plus volts DC, if you don't unhook the connector and see if you have around 150, if you do then you have at least one lamp that is bad and needs replacing, if there isn't any voltage there its the power board
Nov 26, 2017 | Hitachi Televison & Video
Panasonic worldspace digital receiver re -ws10
If it is not faulty, it is not receiving a strong enough wireless signal and you could try it at another locaton where there is a working digital antenna and downlead.
Oct 19, 2014 | Televison & Video
Dead hitachi 443
This unit uses a DC to DC converter, and it is very sensitive to voltage spikes, it does have a fuse on the power supply and it also has 4 solid states fuses that look like transistors and resistors on the power supply board.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 19, 2013 | Hitachi CP-X443 Multimedia Projector
When i plug my wharfdale digital radio in the mains it makes a loud buzzing sound yet works perfectly when using battery power
I assume you are talking about listening on the set's own loudspeaker.
The power supply for the receiver is faulty, it is not producing a nice smooth DC like it should. Is it an external supply? If so try a new one, if not there is a faulty component in the radio power supply.
Feb 02, 2011 | Audio Players & Recorders
I need power cord/power supply for a ws1 bachmann keyboard workstation..where can i get one or the specs and ill make one..thnx JJ
As I have exactly the same unit, I know for an absolute fact that almost every computer monitor with a removable power cable uses exactly the one you need. So either scrounge it from your "spare cables" box, or go to Radio Shack and buy a brand new one.
Dec 21, 2010 | Audio Players & Recorders
I have jvc worldspace digital reciver FR-DS100, as worldspace stop it operation can i get any other station
I have the same JVC Radio Satellite, we are facing a problem now, although and we have this kind of a Radio receiver that in the past used to receive it broadcast from 1WorldSpace Co. but it went bankrupcy, so we are unable to use our Radios, any idea, to whom we would refer to
Oct 06, 2010 | JVC Audio Players & Recorders
E-000003-0000
During printing, the main thermistor detects less than 120°C/248°F for 1
sec or more continuously.
Main cause:
The fixing film unit is faulty (main thermistor fault, thermal fuse blow, fix-
ing heater fault).
Or the power supply PCB is faulty.
Or the DC controller PCB is faulty.
Action1.
Malfunction
Turn off the power; wait for 10 min, and turn on the power. Is the problem
corrected?
YES:End.
2.Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO:Correct the wiring.
3.Fixing film unit
Try replacing the fixing film unit.
Is the problem corrected?
YES:End.
4.Power supply PCB, DC controller PCB
Try replacing the power supply PCB. Is the problem corrected?
YES:End.
NO:Replace the DC controller PCB
Nov 07, 2009 | Canon imageCLASS D320 Digital Copier
Cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Sep 15, 2009 | Hitachi DZ-GX20A DVD Camcorder
Televison & Video Logo
129 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
