Question about Blaupunkt Car Audio & Video
Multi reason back for blaupunkt dv2308 player
Only plays reason 2
Posted by Alan Smith on
1 Related Answer
jaffa012001
L Jefferson
  • 376 Answers
SOURCE: not able to play region 2 dvds
With remote control and player stopped,
press setup, vol+, vol-, vol+, vol-
Use arrow keys to select region 1-6 or 255 for all region.
Numbers appear on TV screen.
Press setup again to save and exit
Try this to make it multiregion. It should work.
Posted on Oct 19, 2008
How do I unlock my blaupunkt tv/dvd combo for multi region dvd's
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Oct 27, 2014 | Televison & Video
Dear all, I have a Pegeute 307sw with a Blaupunkt Audio set with Multi stack CD Phone Nav SAT . Apperently the Multi stack cd is not functioning any more and the buttons numbers are...
Cd changer is mainly a mechanical unit, most common problems are caused by gears and dirty lens.
Try disconnecting the cd changer power cable and connecting it back, if it reset the changer it will restart working normally, if not you have to replace or take out for repair the cd changer.
Jul 22, 2008 | Blaupunkt Car Audio & Video
Car in-dash dvd player went silent, I can see the video, but no sound?
I have contacted a friend who specializes in car dvd players and he said he will try to locate your problem and get back with me. please give me a day or so, but hopefully someone else might give you and answer sooner.
Jul 26, 2007 | Blaupunkt IVDP-01 Car DVD Player
How do i unlock my LG BH7520 blue ray dvd player to play multi region or region 2 thank you
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your player(region free). However, some DVDs (multi region in particular) will not play, since they require region detection from the player unit.
Sep 23, 2013 | LG Televison & Video
How I can take off Random play from bus blaupunkt dvd-player. It shows (Random) on left side on screen when I put DVD in and movie jumps every few minutes. Very bad to watch movies, cause have to find...
There should be a DVD Repeat modes or "Repeat/Repeat Modes" button on your remote. Press that until it's back to "ALL" and it should play things properly again for you.
Aug 27, 2011 | Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car...
I need to be able to play different regions on my DVD player. I have several DVD's from region 2 and I live in region 1 I have a Zenith DVD2381
If your DVD player is not a multi region player you cannot play any other region DVD than the one specified at the back of the player. Check in y our user manual it tell you if it is multi regeon. Multi regeon players are bit more expensive.
Jan 02, 2010 | Zenith DVD2381 DVD Player
Blaupunkt mp3 cd error on home burnt cd-r's
After contacting blaupunkt, they say there is a problem with your unit. Please contact them for repair or replacement
Apr 20, 2009 | RCA TH1101 MP3 Player
My cassette player will not play the radio...
it sound like you fried the radio by taking the fuse out of the system that fuse was blowing for a reason power wire maybe grounding somewher check the power wire with a meter good luck.
Jan 05, 2009 | Blaupunkt Hollywood C30
Multi region code for samsung dvd 5500
um there is a reason why there is differ region dvd's...no player will play multi unless u buy it that way....best bet is to convert your wrong region dvd's to non region
Dec 02, 2008 | Samsung Televison & Video
Panasonic dvd-cp72
asptroy,
hi mate, just want to know first if what region indicate at the back of your DVD player? the reason why i ask you, is because most of branded DVD have their own region for ex. for asian countries they are tagged as region 3 and Australia region 4 ...... most probably your player is not configured to play multi region disc if it can't play any disc. The only way to check if your player have a problem is to check the region of your player and if you can barrow or buy a dvd disc having the same region. or simply check for DVD disc which indicates that it is a all region compatible. Actually this is only info that i can share, but if your only near in my place i can help you change your dvd player to become a multi disc reader simply by clicking some activation keys using the special remote control specially design to configure and modify region setting of panasonic players.
cheers,
markiez23
Jan 05, 2008 | Panasonic DVD-CP72 Multi-disc DVD Player
Car Audio & Video Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Sheldon Dedek
Tom Chichester
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
