Question about Hayward Pool & Spa
How do I get the back panel off of my hayward ultra pro pool pump to repair a faulty switch?
Posted by Marc Bouteiller on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Bought a new home with pool which has the Hayward
Need some more info on the Sand filter. I can help you out. With the rest. Is that the pic of the filter you have. If it is then its a top mount. Depending on the debri that comes into pool, you will back wash 1-2 times a week. After back washing you will turn to rinse and let it run for awhile (of course each time you turn the handle make sure the pump is OFF. Set, then turn on.) then back to filter.. Any Q's just hit me up buddy..
Posted on Mar 11, 2009
superdave1
  • 156 Answers
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Posted on Jul 06, 2009
thepool
thepool
  • 78 Answers
SOURCE: how do you change a pump seal on a hayward 1hp
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
Posted on Apr 22, 2010
thepool
thepool
  • 78 Answers
SOURCE: Hayward HeatPro Heat Pump for pool won't turn on
Power to the unit but not the display + mice = bad board probably. Service call required...
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
Hayward ultra pro lx pump, The On/Off Switch is stuck in the On Position, engine is not running and the breaker is Ok. The On/Off Switch doesn't even want to return to the Off Position. Any ideas what...
Unplug your filter pump motor and remove the back plate. Next, use an Ohm meter to test for continuity at the switch terminals. If you have continuity in both the on and off positions, then you must replace the switch. If not, then you have a short or the pump is wired incorrectly.
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward Pool & Spa
I have a S-244T sand filter and I am noticing that my water level is going down about 3/4
When the pump is running is water discharging from the waste pipe outlet?
If so then the selector valve that switches the pump outlet to waste, backwash, filtering etc. is faulty.
Aug 21, 2012 | Hayward SAND FILTER, PRO SERIES
Hello I'm trying to dismantle my hayward pump, but can't seem to able to remove the turbine... without forcing it too much....any tricks?
IT TURNS OFF TO THE LEFT, YOU NEED A 7/16 OR A 11 mm WRENCH TO HOLD THE ROTOR AT THE BACK OF THE MOTOR.. LOOK FOR THE NOTCH IN THE SHAFT UNDER THE SYNTRIFICAL SWITCH ASSEMBLY , BE CAREFUL NOT TO BREAK ANYTHING ON THE BACK OF THE MOTOR. REPLACE THE SEAL ! THERE IS A GUY SELLING SHAFT SEAL HAYWARD SUPER PUMP MOTOR REPAIR KIT & how to
ON EBAY .. HEY YOU .. PRIME THAT PUMP AFTYER ANY PUMP REPAIR !! THERE NOT SELF PRIMING UNTIL THERE INITIALLY PRIMED IN FIRST PLACE !!! AKA PUT WATER IN THE PUMP !.. IF I WAS OF HELP CLICK ON THAT (YES) BUTTON ON THE BOTTOM LEFT OF THE PAGE.. REMEMBER A CLEAN POOL IS A SAFER POOL .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA ..
Jun 11, 2011 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Hi! I have a Hayward Pro pool/spa system with Jandy valves and I'm trying to figure out how to switch them from pool to spa. Either I empty the spa or I'm heating the whole pool. Help please!
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Apr 23, 2010 | Hayward SAND FILTER, PRO SERIES
How do I connect up a hayward pro grid de4820 to a pool pump
motor gets hooked to bottom ,top is outlet back to pool there should be a bottom drain plug hose to pool goes on top return and on pump inlet
Jul 13, 2009 | Pool & Spa
Pool pump noisy
maybe plugged or restricted with something. try cleaning it and see if that will help.
Jun 06, 2009 | Hayward SAND FILTER, PRO SERIES
Pumps Capacity?
# Aboveground filter systems and small inground pools (under 10,000 gals) should use a Low Head pump like a Maxim, or Dynamo or Power-Flo. # Pools from 10,000-20,000 gals can use a Medium Head pump like a SuperPump, a Pinnacle or Cygnet. # Pools over 20,000 gals could possibly use the High Head pumps like, Super II, Challenger, Ultra-Flo or the Sta-Rite pumps. # Pool/ Spa combos with at least 3 lines influent and 2 - 3 back to the pool, 2" plumbing may be able to handle the Ultra High Head pumps like NorthStar and the WhisperFlo
Aug 27, 2008 | Hayward 2 Hp Max-Flo Swimming Pool Pump...
Pool & Spa Logo
164 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
