Question about Hayward Pool & Spa
My hayward ec 40 is leaking water out the top where the handle is
Posted by Jean Buonaccorsi on
2 Related Answers
Anonymous
  • 8 Answers
SOURCE: I have an EC-40 Hayward
make sure the gasket around the tube sheets is secure
Posted on Jun 21, 2009
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Posted on Mar 17, 2011
How tio replace a regeneration handle in a hayward EC30
Copy following link for hayward product manuals, and contact-us link:
http://www.hayward-pool.com/pdf/manuals/PowerFloLXandPowerFloII.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 07, 2013 | Hayward Ec 30 De Pool Filter with Pump
Water in ec-40 pressure gauge
Water in the pressure gauge indicates a faulty gauge. It will need to be replaced. They usually run $10-15.
Jun 12, 2011 | Hayward EC-40 DE Pool Filter with pump
Water leaking out the top
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
Hayward eC-40 pump losing pressure very fast
A better way to clean the filter tubes in the EC40 is to remove the filter tube assembly and soak it in a 5 gallon paint pail that is filled with a solution of water and a 20% muriatic acid, available at hardware and home center stores. Be very careful handling the muriatic acid. Don't splash it around.
Mix it in a 1-to-1 ratio with water and soak the assembly for at least 8 hours. Keep the soaking pail out of the reach of kids and animals.
Remove the assembly, properly dispose of the acid mix and refill the pail with clean water. Soak again for 3 to 4 hours, then reassemble your filter.
Some pool guys say it isn't necessary to soak the tubes in clean water because the muriatic acid will not harm the pool water and will reduce the pH if it's too high. I've always soaked them to be safe.
This is a link to the Hayward manual that describes the process:
www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jun 25, 2009 | Hayward EC-40 DE Pool Filter with pump
Hayward pump wont prime. air bubbles coming back into pol with water and de
You have a leak, if DE is getting back in pool your filter is either dirty and needs to be taken apart and throughly cleaned, or you have a ripe in one of the DE cells. The pump not priming is a leak somewhere before where water enters pump. Could be a bad o-ring in a valve. Hard to tell what is is without troubleshooting, piece by piece. I would start with cleaning Filter first.
Jun 17, 2009 | Hayward EC-40 DE Pool Filter with pump
Pool & Spa Logo
145 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
