Polaroid FDM-0700A 7 in. TV/DVD Combo Logo
Question about Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid fdm-0700 with black screen display. DVD
Polaroid fdm-0700 with black screen display. DVD and sound OK. Sound ok in all modes. Display screen stays black.
Posted by cpriemon on
Anonymous
Go here to see a how to replace the board
http://clickondavid.com/photo1.html
And downloada pdf on the procedure
Posted on May 14, 2010
Anonymous
    Problem Solver:
  • 4 Answers
Go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Posted on Aug 21, 2009
2004 Honda Odyssey - DVD player working fine until now suddenly the picture does not come on screen but there is Sound from Speakers?
So it is the fault with the display unit unless the video processing section of the dvd is faulty. So cross on the display unit if there is indication of the mode then the display is Ok and the fault is centered on the DVD.
The Digital to Analogue convertor can be faulty so that there is no video output to the display.
The unit may need expert attention.
I have the Polaroid dvd player PDV-0700, it will not power on or anything
The PDV0701A will not power on and screen is black . If you turn switch off white lines appear on screen as it turnes off . No sound and dics does not move . Please advise .
3helpful
How can I get a replacement remote control? Or is there a local place I can pick one up close to zip code 13901.
Hi heres one on ebay for your model
http://cgi.ebay.com/POLAROID-PORTABLE-DVD-PLAYER-REMOTE-0700-SERIES_W0QQitem
Z260547047090QQcmdZViewItemQQptZLH
_DefaultDomain_0?hash=item3ca9d06eb2
please dont forget to rate me i need a few more to get my badge thank you....
Won't play movie
sounds like the dvd is bad, try another dvd if that doesn't play then it is the player.
Only Sound
Could be the monitor settings don't match the video output or the video card has failed. Try entering the BIOS setup screen at startup. Usually the 'DEL' key held down. If screen is displayed (It will be in default VGA mode at that point), then you know the video stream is OK. Continue booting, and press F8 to enter windows safe mode, and continue from there to get the display parameters corrected.
Portable dvd player
Polaroids are well known for this issue you can try to replace video cable if that doesnt work if still under warranty send it in if not you will need to make a video rca repair
c.
Help
Ok this is a sure fire way of getting that DVD out. Open up the unit, find the load and unload gear, rotate the gear and that should eject the carriage slide. That's it.
Polaroid 0722 Player
On most of the set top DVD players you use the monitor button or the remote control menu button to access the mode that flips the display (invert). The mode is for those who mount the units to the ceiling of a vehicle for rear passengers to view. You might have to have a DVD playing at the time or just loaded in the stop mode to access the feature.
No picture
sounds like the back lightsd not working. if you know how to work on electronics maybe you can go in and see if the bulb is bad or the power supply that feeds it. Good luck
Top Polaroid Televison & Video Experts
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
