Led is turning on, I can hear relay but no VCC on fuses. More details to come:
SOURCE: dead Peavey audition chorus practice amplifier.
Hi...
There's probably a 5 pin power amp IC on a heatsink inside
replace it
SOURCE: will not turn on can hear relay? click right LED flashing other solid
Did you try to switch the TV of with the on / off button or switch on the TV, not with the remote and not by unplugging the mains?
Then try again.
SOURCE: will not turn on can hear relay? clicks right LED flashing other solid
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
