Question about Technics SL-1200 Turntable
Is a Vestax VR-3S cartridge compatible with a Technics 1200 turntable?
Posted by stephenhero6 on
Tony A
  • 189 Answers
HI!
I understand the Vestax VR-3S cartridge is moving magnet (magnetic). Provided it is wired correctly there should be no problems. Any magnetic cartridge will be compatible.
CHEERS :-)
Posted on Aug 09, 2009
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
I have a technics 1200 mk5 and when i put a record on the volume is low no matter how high i pt it up in the mixer. When i use it with serato it works fine. What can be the problem?
Years ago, Radio Shack sold a turntable with the same problem. The fix was to purchase a pre-amp to go between the turntable and the tuner/amp. I think this had something to do with a magnetic vs. ceramic cartridge?
Dec 14, 2010 | Technics SL-1200 Turntable
What needles are compatible for the technics 1200 m3d
All you need to do is look at the cartridge. It should have a number on it. Put that into google and you should find the answer!
Sep 04, 2010 | Numark BATTLE PAK v.4 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Sep 22, 2009 | Technics SL-1210 Turntable
Low volume on both sides
Make sure you connected the turntable to the PHONO INPUT of your Vestax Mixer. If so, then the problem might be with your mixer output, or your sound system. You will need to test each unit individually to determine what the issue might be.
- OPTiC
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 20, 2008 | Technics SL-1200M3D Turntable
Technics SL-1200 Turntable Logo
89 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
