Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution... * 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and then press the "eject" button. If this does not work, turn it off and unplug the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out.. * 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing. * 3 Look for the DVD holder inside the DVD player. This device holds the DVD in place while the DVD player reads the disk. * 4 Push the stuck DVD disk toward the front of the DVD player until the DVD ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied. * 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly.. * 6 Replace the casing and the screws. Plug the player in and turn it on. Put another DVD in to test whether the player is finally working .. Hope this helps!.. Take care and please Remember to rate/vote and give us 4 Thumbs Up to continue for Helping out the Community :) .
you must remove the region lock off the DVD image you're trying to burn make it region free. your DVD player might have locks on which DVD regions you can play, your DVD writer doesn't come with a region lock that's why you're able to play the disc
Dear! It is the fault about belt of a CD/ DVD Rom. You can remove this fault if you can change the belt that is inside the CD/ DVD Rom. And if you want to eject your disk as soon as possible? Use a pin and put inside the very small hole of CD/ DVD Rom and press under your controle slowly. Your disk will open.
Thank you.
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Place a disc in the tray with the label facing up. Let it try to read. If the disc is still oriented the same way after it fails, odds are 99 out of 100 the motor has failed....sorry, buy a new one if warrantee has run out.
Basic DVD, CDrom Troubleshooting wrong disk ,disk error, First Clean the lens: http://www.ehow.com/how_2036275_clean-lens-dvd.html wont open, wont close, makes clicking/grinding noises etc. http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
