Toshiba Portege 7220CTe (PP722U-7D90Q) PC Notebook Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My toshiba 7220cte will not load a fresh win 2ooo os , fdisked and formatted drive. tried loading from cd and floppy disk. at very end of install. unit shuts down , and states i have an invalid disk in unit. can anyone help !!! thanks , chip
  • Joe Goldman
    Joe Goldman May 11, 2010
    haven't used a win 2000 cd in a while so....Using a windows xp cd - boot to the recovery console and get to a command prompt. type 'chkdsk c: /r' with no quotes. this will check the partition for file system errors. If you are able to attach the hard drive to another pc with an external usb controller, you can chkdsk that way too. If it reports no problems, try this: Create a partition on the hard drive before installing windows then install to that partition. try creating a partition with an xp cd or be resourceful and try to find a boot cd that will let you create partitions on a hard drive. hope this helps!
Anonymous
Level 2:
Sergeant:
Novelist:
  • Expert 192 Answers
  • Posted on Aug 09, 2009
Anonymous
Expert
Level 2:
Sergeant:
Novelist:
Answers
192
Questions
Helped
64990
Points
565
If you have an invalid disk in the unit, is the floppy disk left in the disk drive.
However, to completely erase windows, fdisk and format does not work.
Download delpart.exe and use this utility. Be careful though. When delparting a laptop, make sure not to delete the small partitions, but only the ones that are NTFS.
However, if the laptop has a SATA hard drive, this method will not work unless you create a bootup script with delpart.exe to run automatically. Then it will work.
If you have any issue, blog it on the internet about the exact procedure to create an iso bootable disk to load delpart.exe.
I am having a toshiba portage m205 with win xp . Windows got crashed when I tried to load windows with recovery cd It doesnt recognize its recovery disk Pls help .
Hello
you can do one thing
with that your data will be saved.
try a bootable cd of win XP & install os again without formating C: Drive, just overwrite the os instalation in same drive.
maybe after that your problem will be solved
Thanks
I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
They may have a restore floppy if you need it too.
One for "recovery files" and one for "OS Boot"
AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
Restore CD should do it all though.
If no restore CD - have Win98 CD?
if Harddrive partitioned and formated - Just do 1
1. boot from Win98 CD.
Partition n Format
2. Choose boot to DOS (puts u in virtual drive A)
AT PROMPT
3. Type drive letter of CD ( C: D: or E: )
4. Type CD Win98
5. Type Fdisk ( to partion drive)
reboot n do 1 + 2
6. Type format C: ( I do this to ckeck drive for errors)
OR
JUST Boot from CD and follow install instructions.
1 to 6 for if you have problem with Win98 CD setting up Harddrive.
2helpful
2answers
How to reformat my MSI notebook?
You need to have an valid Operating System installer CD/DVD. This could be a Windows or Linux installer or whatever Operating System that you prefer.
  1. Turn your laptop on.
  2. Open the CD drive and load the CD Installer.
  3. Reset your laptop to manually reboot it. If you loaded the CD fast, this step is no longer required.
  4. The setup program will then load. Follow the onscreen procedure.
  5. At the point of selecting the hard disk drive, choose "Delete Partitions" to completely remove all data.
  6. After deleting partitions, create new partitions for your hard disk. You can choose to divide your hard disk capacity into 2 or more partitions depending on your requirements.
  7. Format the root partition now (Drive C) to continue the installation.
1helpful
Laptop wont boot...it wont load past the very first boot screen where it asks you to hit f12 for boot menu and f2 for system utilities it have the windows vista OS...is there a problem with the hard drive?...
Windows is corrupt...reload Win OS....if possible re-install Windows in a different partition say D: or E: etc (if u have more than 1 partition) and then once done let it boot from that and let Win load....take a full backup of all of your critical data to a USB pen drive....then reload Win CD in the Cd drive, switch off and switch on PC let it boot from CD and delete all partition on HD, format the disk fully and repartition the disk and load Win in C:
pls leave a feedback
How to format a Toshiba M100
get a win 98 boot disk floppy. set bios to read floppy or usb floppy first save and exit. insert disk and boot comp. select boot without cd rom support. At command prompt type " FDISK " then hit enter dont type quotes. delete the particians then create new partician set 1 particians as active then remove disk then insert OS disk and go forth. I after you install your new OS and you get two boot options at the command promt after loading type " delpart " and delete the particians and save (use the tab and alt keys to bring up menus save and exit before you leave delpart) reboot and run fdisk to creat a partician and set it as active. then load your OS
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
2helpful
I couldn't install windows xp in Compaq cq45 112au
Try using an win 98 startup disk on floppy and start your computer with disk in.Let it finish loading the drivers and then type in fdisk erase your partition and then make a new one. then restart the computer with floppy still in then this time type in format c:/ and format the drive after it is done then you can install win xp.But you need to repartition your hard drive and then format after that to get xp to install Oh yeah when you go to fdisk allow large drive usage
Step by step on how formatting and fdisk and installation?
Okay, heres what ya need to do.
Procedure:
1. Get Windows install disk(s).
2. Turn on computer with cd in drive, press F12 or F2 untill you get to the options that allow you to boot from the CD.
3. Delete all partitions after CD loads, then create new partitions.
4. Then continue on the installation and click next untill its done.
5. to make fdisk, put in a floppy drive after the installation, Go to My Computer, then right click on the floppy drive and choose create fdisk.
Hope this is clear enough, if its not just ask.
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
4answers
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
