Question about Olevia LT32HVM 32 in. LCD Television
Picture on Olevia lcd is too large for screen.
No matter what aspect i choose, the picture on my Olevia lcd is too large for screen. Sports scores, tv station logos, subtitles are all cut off. Can't change it no matter what aspect i choose.
  • 30 Answers
If you are on a cable or dish box, check aspect setting from you box, TV needs to be 16-9 or full, set TV first then change setting on box.
Posted on Aug 09, 2009
Was having same problem and was able to fix the problem by selecting HD Zoom button on cable remote.
Posted on Feb 27, 2012
Anonymous
SOURCE:
How do I change the picture size on my Olevia tv
Our 47" Olevia remote uses 'Aspect' to set/change the size and aspect ratio of the picture- look to see if yours is also so marked.
Sep 28, 2014 | Olevia LT42HVi 42 in. LCD Television
Picture too wide for the screen
Press the "View Mode" button on the remote control. A list of available aspect ratios appears on the screen.
Read more: http://www.ehow.com/how_8668256_change-ratio-sharp-aquos-tv.html#ixzz2yWjUJlEr
Apr 10, 2014 | Sharp LC-32D47UA 32 in. LCD HDTV
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
The picture on my 32" screen Olevia 232 S12 has become too large for the screen. Changing aspect ratios does not fix the problem. What's to be done?
Are you using a cable box?>
if so, try changing the resolution on it...most of them have a pound button (#) that allows you to change the resolution, from your remote.
Oct 11, 2009 | Olevia LT32HVE 32 in. LCD Television
Olevia 37" Hd flat screen, picture does not fit screen. Sporting event scores are off the screen.
You need to check the aspect or screen size settings on the TV as well as your signal scorce IE: cable box, satelitte if they are HD?
Sep 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Aspect ratio, cuts off edges of picture.(NOT THE T.V, THE RECEIVER!)
Dilon, 311's have no aspect ratio adjustment and is not able to switch from the standard 4:3 setting therfore if it is connected to a TV with a large screen the TV has to stretch the picture to fill the screen thus cutting off portions of the picture. I suggest you get a HD receiver as they will be able to change the format and aspect ratio but even these make some sacrifices to fill the screen as well. Most notable of the losses will be the ticker tape at the bottom of the screen where sports scores usually are displayed. Thhis is all a result of the plethora of screen sizes on the market and will not be resolved anytime soon that I am aware. Dish has a 211 which is a one room HD receiver, 612 which is a one room dual tuner receiver with DVR, 222 which is a dual tuner two room receiver with HD capability to the first location and SD to the second, 622 and 722 which are both dual tuner two room DVR receivers with HD to the first location and SD to second. I am sorry I could not bear better news but I wanted to thank you for using Fix Ya and if you need further assistance please let me know.
Jim
Nov 09, 2008 | DISH Network 311 DTV Receiver
42 inch olevia
If you're sending an HD signal to the tv use either 1:1 or Aspect viewing modes.
If you're sending an SD signal you'll not be able to get a full screen view unless you use zooming.
Dec 04, 2007 | Olevia LT42HVi 42 in. LCD Television
Aspect ratio
You may have a vertical circuit problem causing the picture to stretch out. This is called "over scan". You need to have a tech check it for you. Stargazer
Apr 19, 2007 | Sanyo DS24425 24" TV
Olevia LT32HVM 32 in. LCD Television Logo
555 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
