How do I get my password and username when I changed it and it makes me start agian if I log in with my email
I have to start at level one if I log in with my email
5 Related Answers
networkmagic
  • 139 Answers
SOURCE: I need to change my password and username!!
After you log into the router, from the main screen, click on "Management" > "Access Control" > "Passwords". You can enter a new password here.
More details are available on page 86 in this manual on the Zhone web site.
Good luck...and I hope this is helpful!
Posted on Jan 14, 2008
Anonymous
SOURCE: sharp ar-m237 default username and password
admin
Sharp
Posted on Apr 04, 2008
Anonymous
  • 5 Answers
SOURCE: I cant log in with my username and password
Reset the router to factory defaults by putting in a push-in in the small hold at the back of the router. You should then be able to login using the default password. Default password should be in the user manual.
Posted on Dec 05, 2009
NextStepComp
Brad Hays
  • 185 Answers
SOURCE: Facebook doesn't recognize my email or password!
Check here http://www.facebook.com/help/#/help/?page=174 for login related problems. The most common issue is capitalization where it is not suppose to be.
Posted on Dec 31, 2009
Anonymous
SOURCE: Easycap 4ch usb DVR no email sending
when i use multiviewer and set up mail, it tests ok but will not send an email.
i think it has limitations, the first email i setup had secure login required, and that didn't work, so setup another that wasn't a secure login server. and that tested fine.
but still trying yp get it to work.
Ritchie
Posted on May 07, 2010
How do I fix my email accounts from asking for Username and Password every time I log on?
some will save passwords and some will not . sounds like you have a server problem that the other end needs to fix
May 12, 2015 | Computers & Internet
I forgot my username for instragram
If you're trying to log into your account but can't remember your username:
  1. Tap the Forgot your password? link on the login page
  2. Tap Username or Email
  3. If you don't see your username there, enter your email address and we'll send you an email with your username in the greeting
If you're logged into your account, you can find your username at the top of your profile.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_195f36f311cb10df
Dec 03, 2014 | Facebook Instagram
My username is 4 numbers. It won't let me log in saying I don't have enough characters. How can I log in or change my username so I can log in?
go into the log in page - hit "forgot user ID" - they will email you a new one or email you a link to pick a new one - use at least 8 characters. Then go back to log in enter & enter your new user name. Try your old password - if that doesn't work, hit "forgot password" & they'll let you reset.
Apr 06, 2013 | mywalmart.com
Changing my fixya username and password to my facebook info
Absolutely! Simply make sure to change the email address you use on FixYa to match the primary email address you use on Facebook. (The passwords do not need to be the same).
  1. On your FixYa Homepage click Edit next to your name.
  2. Make sure your email address matches the email address you use for Facebook (I would suggest your primary Facebook email address).
  3. If it does not, simply type the email you use for Facebook and click Save.
  4. Log Out and then click Sign In.
  5. Select the option to Sign in using Facebook.
  6. Once you have accepted the terms, a module with your information will appear (pictured below). Select Continue.
You will now be able to log in to your FixYa Profile using Facebook. All past information will be in tact and your Facebook Profile Picture will be your new FixYa profile picture!
  • Note: Username is simply what FixYa uses in the URL for your Profile.
Mar 14, 2012 | Facebook Social Network
I lost my skype password
You can still reset it. Open the Skype, enter your username, click "Forgot you password?", (you can do even if you don't enter the username, but it's better since you'll be taken to your personal page, check the url, you'll be be able to see your username).
another windows will open up on the Browser, there, you'll see box "Enter your email address", type in your email address and click "submit"
You'll receive a temporary password (or password reset link) on your email (sample email shown below). Use the code to login and change the password after you are logged in. Note: to change the password, you'll need the temporary password, so don't delete the email, better note it down and change it once you are logged in.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Feb 05, 2011 | Computers & Internet
Forgot password
Another windows will open up on the Browser, there, you'll see box "Enter your email address", type in your email address and click "submit"
You'll receive a temporary password on your email. Use the code to login and change the password after you are logged in. Note: to change the password, you'll need the temporary password, so don't delete the email, better note it down and change it once you are logged in.
Good luck.
Nov 16, 2010 | Skype IM
I forgot my skype password
Good luck.
Nov 02, 2010 | Skype IM
I forget my pasword
Good luck.
Sep 20, 2010 | Skype IM
I forgot my password
Good luck.
Sep 12, 2010 | Skype IM
I cant remember my password
If you don't remember your password on bebo but remember your username, go to www.bebo.com and click 'Forgot Password?' and type in your username and type in what the code says, type in ur birthdate, your question, and your email and new password. Once you have done that, an email will be sent to you letting youk now you changed your password and youm ay start using bebo on your old account once again.
Hope this helps!
R0ckinrit
PS: You can still log on to bebo with your old account without cheacking your email.
Jul 18, 2009 | Bandai Digital Entertainment Cowboy Bebop
Computers & Internet Logo
15 people viewed this question
Ekse
Marvin
Marvin
