Question about Fisher and Paykel Washing Machines
Two of the elements of our Fisher and Paykel Saffron stove stay on full, they will not turn down. Can anyone advise of our next steps. Thank you
    Master:
  • Fisher and P... Master
  • 745 Answers
Each element switch controls the heat to that element so those switches need to be replaced ,technical name is simmerstat
Posted on Sep 08, 2019
2 Suggested Answers
6ya staff
SOURCE:
galadToo
SOURCE: I have a Fisher and Paykel Saffron oven - stove to...
The temperature switching device has 'died', and needs replacing. This is a continual problem in these stoves (we have replaced each of ours at least once or twice in the 7 years we have had it). I will never buy another F&P oven!
The only solution is to get F&P or another repairman to come out and fix it. It cost us $AU 215 each time.
Posted on Sep 29, 2010
How to set clock on saffron stove fisher and paykel
as it shouls calways be off at the wall when not in use, but if you want to then press the two left and the second to last button all at the same time
Apr 27, 2018 | Fisher and Paykel Ovens
Fisher paykel problem
sounds like you have a problem with the thermostat it may need to be replaced. \you can goole appliance parts and you will see a number of dealers you can get parts from
May 04, 2014 | Ovens
Hi, I have a Fisher and Paykel Thyme Stove and the two big elements wont turn down, Whats wrong and can it be fixed cheap?
this is a common problem ,the switchs that turn on the elements are called thermostats,and they are faulty, an easy repair by any electrican
Sep 26, 2012 | Fisher and Paykel Ovens
Fisher and Paykel refrifgerator F02, F07, F17
ok thats a defrost element like in a stove but not as hot its located in behind the paneling in the freezer
Mar 01, 2018 | Fisher and Paykel Refrigerators
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a Fisher and Paykel Saffron oven - stove top elements have started only working on high - unable to turn these down.
May 16, 2010 | Kitchen Ranges
Hi my Fisher & Paykel Paprika stove (Model FPRA6102AW) Needs a New Oven element, and 3 of the plates stay on Hot. Are these parts available and how much would they cost please: x1 Oven Element x3 Switch...
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Mar 05, 2009 | Fisher Ovens
Stove element malfunction
THE THERMOSTATIC HEAT CONTROL SWITCH NEEDS TO BE REPLACED.
Oct 13, 2008 | Kitchen Ranges
Fisher and paykel stove/oven
This range has faulty simerstats they need replacing.
Jan 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
