Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hi, Is your Zeki fully charged? My suggestion is to hold the on/off button for a few secs. to fully power down. Put it on the charge and let it fully charge before trying it again. Then try turn it on again.
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
press and hold the red button that you use to cancel or disconnect calls till the phone starts to shut down. the phone will switch off..repeat the same for switching on as well
in this phone when the battery is fully charged the running battery
indicators stop at full position. U must charge every phones battery a
maximum of 2 hours b'coz charging more than it reduces battery life and
if the battery is not fully charged in 2 hours u must charge it after
20 minutes again
