Namco Ms. Pacman Galaga Cocktail Video Arcade Logo
Posted on Aug 09, 2009
No power from board to monitor
Just bought this cabinet. When I turn it on, I get a "no signal" message on the screen.
repairyes
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Apr 21, 2010
repairyes
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
13067
Points
50
Check all fuses and power supply to the board. The monitor uses a seperate circuit, thus comes on independently of the board.
Check all plugs to the monitor, and all grounds. You should be able to get a manual online of this unit.
2answers
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Monitor keeps shuting down
what do you mean by "computer starts"????? plz write full detail. first remove your monitor cable from your cpu cabinet. if you are able to see "no signal" message on screen then your monitor is working. if you aren't seeing anything on your screen then there is some problem with your monitor. there also may be problem with your VGA connection (VGA or D-Sub wire). remove and reconnect this wire from both end. first reconnect it from your monitor and then from your video card. if it dosen't fix then you have to check that all led's are glowing on your cpu cabinet or not. if only power led is glowing and other led's always remains off, then there may be problem with your video card or ram or hdd. first open your pc case, then if you have video card, then remove it and put it again. reconnect your hdd sata wire. remove your ram and place it again. if now also not showing anything on your screen, then there is problem with your motherboard bios.
No input signal message and screen goes black
Check your video cable going from your monitor to the pc. If your trying to use more than 1 monitor, is your video card capable of using more than 1? Are you using the mother board video card or a store bought one?
How do i remove the no signal message on the upper left corner of the screen
The reason your getting that message on the screen is because the monitor is not recognizing a video signal from the computer. Make sure your hooking up the monitor to a working computer because then when you go to turn on the computer the message will go away on the monitor.
If you know your computer is working and the message doesnt go away then its an issue with the main board inside of the monitor and since no parts are available for that, you would have to get the monitor replaced.
As soon a the Monitor turns on...the green light turns to orange (this usually comes on when the computer is idle) with the same black screen.
Please check by removing the VGA Cable from the Cabinet and check the whether are you getting VGA connection message on the monitor screen or not ?
If you are getting the message on the Monitor screen after removing the cable then check the Mother-Board
or else get monitor repaired
When I turn on my pc 170l this message appears on
For that first open cpu cabinet then reattach the RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Make sure motherboard is not ground with cabinet.
Remove pci cards from motherboard if any .
Reattach vga card if installed.
reattach processor and its fan.
Then when you power up the computer press F8 key then enter in enable vga mode then go to display property and set screen resolution to 1024*768 then apply and ok.
Let me know if you need further assistance.
Thanks for using FixYa.
3answers
Lights and Fan are working, but no beep.
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Flat screen monitor comes up with No Signal
If it goes to NO signal again, its not necessarily the whole Flat screen that is dead. Just replace the Video logic board with a known good one and it should work
Most monitors only have 2 or 3 boards
Logic board, Inverter, Power supply
or Logic video ,and a power supply board with an embedded inverter.
You have to open the monitor and replace.
2answers
No Signal
No signal on screen means that there is no input for your monitor from the PC.
1. There might be problem in your PC or in the cable connected to PC from monitor.
2. Your PC might damage that it could not send signal to the monitor.
2.1 In your Motherboard might be faulty in the VGA chips.
2.2 In your Motherboard's SMPS mean power supply.
I think you can got my point. If you are tech person it will help you, otherwise you should take a tour to any service centre.
Thanks & Goodluck
Iqbal
Top Namco Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Namco Toy Expert? Answer questions, earn points and help others
