I have a Jenn-air 731W and noticed today that there is a loud grinding noise during wash cycle. Also the top arm wasn't moving. It did however clean the dishes. Is this the start of a problem?
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
If you hear unusual noises during dishwasher operation, check to see if
a dish or cup is loose and being knocked around during the wash cycle.
If you hear grinding, grating, crunching or a buzzing sound, chances
are a hard object has gone into the wash module. Once the object is
ground up, the noises should cease.
Is there a chance the dishes are moving when the machine is on? Cound the water jets(spraying the door and sides) be the cause of the noise. Is the sound insulating blanket on the outside of the machine? Try running empty on a shor cycle to help diagnose the problem.
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
If you remove the back panel, there are two pumps towards ethier side at the botom of the tub. If you remove the back hoses (have some towels ready) You may find something in one of the two pumps.
You might have something bouncing around in the wash pump inlet in front of the "chopper". Remove the lower arm and upper arm supply tube. Remove the screws then remove the screen, accumulator and inlet protector. You should see debris in front of the screen.
