Question about Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300
Will not turn on. It's brand new and it just quit working. When I push the power button, nothing happens.
Posted by macdebscott on
cicelymarsha
Place it on its front on the floor and give the back a hit, then turn if on. The balls just got stuck. Fixed mine!
Posted on Feb 15, 2012
Anonymous
    New Friend:
Where having the same problem, if you find the answer please email [email protected] many thanks
Posted on Dec 11, 2009
Anonymous
    New Friend:
Shiatsu massaging cushion stopped working with the balls positioned at the top of the cushion. now it won't do anything.
Posted on Dec 07, 2009
Mikhail M
    New Friend:
It broke on me for the second time. In the past I fixed it by replacing a 4A fuse inside. This time, as soon as I plugged the thing after replacing the fuse, the fuse burned out spectacularly. So, I had to dig deeper. So far I found two problems: a bad rectifier bridge on the control board with the relays and I have also found that the 12V power supply for some reason produces 22V. I am going to replace the bridge but don't know what to do with the 12V supply. I wonder if the marking on the boards and on transformer is wrong?...
Posted on May 13, 2014
My 2005 arctic cat 250 will not start I have a new battery new starter solenoide and good fuses new spark plug gas and nothing happens I have bypassed the electric push start because it quit working that...
With the ignition on, short across the starter solenoid and see if anything happens. If it tries to start (or fires up) then the problem lies with the feed to it so I would suggest re-instating a working push button and wires.
Mar 10, 2015 | GAS Motorcycles
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Tower gets no power
90% of the time this symptom indicates a bad power supply.
If a generic system and in some name brand systems, the part is quite cheap (about $40) + labor.
In rare cases, the power switch could be bad.
Oct 25, 2008 | Power Up (TC3J-4048)
Brand new and no power, does nothing
try pushing the reset button with a safety pin. Its on the back of the mp3.
Sep 24, 2008 | RCA JET S2002 MP3 Player
Menu Problem
Did you try calling Canon tech support or returning to retailer if the camera is really not functioning properly this soon after purchase, I'd try returning it once all troubleshooting issues have not resolved the issue.
Hope this helps!
Feb 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Gps
hold power button down for 3-5 seconds.
Jun 17, 2007 | Lowrance Iway 500c GPS Receiver
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Logo
1,917 people viewed this question
Top Homedics Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
