Question about Kenmore Sewing Machines
My kenmore 158.13500 sews backwards - Kenmore Sewing Machines
Posted by David Navarro Jr. on
2 Related Answers
Anonymous
SOURCE: serger
As long as this is a sewing machine and not a serger, I don't know about them. I only tinker on my own. Remove the bottom. There is a rod running along the length of the machine. it needs to be turned 180 degrees. You may need to retime the machine.
Posted on May 29, 2009
Anonymous
  • 4 Answers
SOURCE: I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Posted on Oct 16, 2009
My sewing machine kenmore
Is your machine battery operated? If so, make sure the polarity is correct. If not, take apart the sewing machine and make sure the polarity is correct.Hope I helped!
~Conner
Nov 27, 2015 | Kenmore Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
My sewing machine sew backward
Many Kenmores get stuck in reverse because the lubricant used has hardened up on critical stitch length/reverse mechanisms. Take it to a good sewing machine repair shop.
Jul 21, 2009 | Kenmore Sewing Machines
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Serger
Oct 03, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing MAchine Problem
redo the bobbin, maybe its backwards.
Jun 23, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
