Question about GE Washing Machines
Ge front load gfwr4805 won't spin or tumble after it quit from a power surge.
Posted by Eric Nostdahl on
5 Related Answers
Anonymous
  • 1865 Answers
SOURCE: front load washer
Possibly the door switch...check for adjustment or replacement
Posted on Apr 18, 2009
Anonymous
SOURCE: front loading washing machine will not tumble or spin
This sounds like a drive belt porblem. The belt that connects the drum motor to the drum has slipped/broken/worn out. A new drive belt will most likey fix this one...
Alternately, a loose or broken pulley. I don't suspect a bad motor, since you say you can hear it clicking and whiring...
Posted on Jun 10, 2009
Anonymous
SOURCE: ge front load
I had the same problem. There is a filter under the front lower panel. You need to remove the four screws and on the right side you will see a filter this gets cloged easly. One time there was a sock in it. I do not know how, but clean your filter and this should help. I hope this helps you. Bubba
Posted on Aug 01, 2009
Anonymous
  • 121 Answers
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002 Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
Posted on May 08, 2011
Anonymous
  • 9 Answers
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
Cycle pauses after about 6 minutes. It doesn't want to spin. In test mode, I'm getting error code E46. With tumble test, motor only tumbles in one direction. With spin test, motor won't spin at...
From what I just read if the same model sounds like the motor sensor could be bad It says it should read around 118 ohms at the two yellow wires when disconnected at the board.
Not sure if the motor will have to be replaced if the sensor is bad
the inverter can also be the problem
Google GE front load washer won't spin or tumble for more
May 03, 2017 | GE GFWN1100LWW Washer
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Ge front load won't spin
Does the drum turn at all? if not it will be the motor brushes, Also check the drain pump for blockages and make sure the pump is functioning.
Mar 12, 2012 | GE Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
The motor is going bad...
heatman101
Sep 07, 2010 | GE WJSE3110A Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
