Question about Apple iPhone Smartphone
MY IPHONE WONT TURN ON
Idk what happend the battery was half-way full when i turned it off to like lock and now it wont turn on PLZ HELP!!
Posted by christina152 on
Anonymous
    Problem Solver:
  • 12 Answers
Check tthe back of the iphone is it hot if it is let it sit until it isnt then plug it in if that doesnt work put the phone into dfu mode (Hold the home button and plug in the usb cable into the fone
Posted on Aug 10, 2009
My iphone turned off by itself and it wont turn back on
hold the home and lock button at the same time and it should turn back on, have it charging when doing this
Jan 18, 2011 | Apple iPhone Smartphone
My iphone died and the apple wont even turn on ive tryed everything on this page and nothing worked can anyone help me.....plz
I would connect iphone to cpu with itunes then hold sleep/ wake and home button for a full 2 mins - if you dont see the apple the ipod is dead you need to call apple for replacement
Apr 13, 2010 | Apple iPhone Smartphone
Iphone 2g not starting back up after reboot..
When the device is locked up like this hold down the lock and home buttons. After a few seconds the device will turn off, immediately let go of both buttons. Now press down and hold the home button. Hit the power/lock button one time. Continue holding the home button until the phone boots up. It will need to be connected to iTunes for recovery at this point.
Jan 27, 2010 | Apple iPhone Smartphone
22 hp B&S wont start
Disconnect and clean the battery termials and cables then reconnect the cables. Connection could be dirty. If that doesn't work make sure the battery has a full charge over 12v with a volt meter. If you have some jumper cables jump it from another battery.
Jan 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
My Iphone wont turn on
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Mar 24, 2009 | Apple iPhone 3G
Car wont start when i turn the key
Check your battery connection both @ the battery, ground connection on firewall/fender and starter/solenoid .. you have a loose or bad connection ..
Mar 20, 2009 | 1992 Ford Escort 4 Door
My phone wont turn on
maybe your sim is block if you have a sim card you can see the label of sim card p,u,k pin code try to type a p,u,k pin code thats all....
Nov 17, 2008 | Nokia 1600 Cellular Phone
Apple iPhone Smartphone Logo
151 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
B Louis
Level 1 Expert
Jax Planet
Jax Planet
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
