The headset is a replacement. I can only get a red light blinking when I put it on the cradle. As soon as it is removed from cradle, there are no lights, which tells me there is no communication to base. I've already completed the routine for synching up a new headlset per the manufacturer's instructions The base is a BCE-GN9120 THanks! Henry
Hi
this has not synch up keep headset in cradle and remove power at mains plug or power lead from base count to 5 and replace power if no flashing is seen then you might have to repeat the same procedure a few times for synch to happen
the only other reason for no synch is battery in headset is not charged enough
Steve
