SOURCE: repair the maytag commercial washer with out coins selector
your bearings are going bad. you need to replace the bearing on the top of the brake packag and might have to replace the tub bearing also
SOURCE: washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: My Speed Queen washer is making a loud squeaky
Those brake pads are probably thin and not holding the tub like they once did AMANA WASHER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thank you for the great solution to my washer problem. The picture really helped."
SOURCE: Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
