Question about Lexar JumpDrive MP3 Player
I lost the user guide to my Lexar MDA256-100 MP3 player and memor
I lost the user guide to my Lexar MDA256-100 MP3 Player. Where can I get another copy of it and what memory cards are compatible with this model? Is a SCAN DISK memory card compatible?
Posted by ecastan on
Anonymous
I want a manual for my iPod nano16Gb Model # A1373.
go to a[[le support enter model scale down to model than select print user guide
Apr 13, 2014 | Apple iPod 16GB nano Silver 4G...
Lost memory card
Your documentation should tell you compatible cards. If you don't have documentation please visit this page:
http://portablemedia.manualsonline.com/manuals/mfg/koss/koss_mp3_player_product_list.html
Jan 20, 2014 | IBM Electronics - Others
I can download music from my PC on to the internal memory as soon as it is full itwill go no further. I have an 8gb SD card installed but it does not recognise the card. ( **** Smith )
It could be the MP3 player doesn't recognize an 8 gb card... try a smaller one
OR
The SD card could be bad... try it in another device you know suuports an 8 gb card
Jan 08, 2011 | Lexar LDP-600 MP3 Player
How i can attach mp3 or memory card with my kenwood player
Hi.
If the Kenwood is compatible with USB memory adapter, then you will have an USB port on the front side of the player, just aside the CD slot.
If the stereo is MP3 compatible, that does not mean that the unit is compatible with USB devices.
If the Kenwood is MP3 but not USB compatible, you can play MP3 files burning them onto a CD, then playing the MP3 CD in the CD player.
Regards.
May 25, 2010 | Kenwood KDC-MP228 CD Player
How do you put music on a Lexar memory disc?
To connect the SD memory card to the computer you need a USB memory card reader. Plug the SD memory card into the USB card reader and then plug the card reader into the computer's USB port.
The computer will see this as an external memory card, you can then click on this memory card (it maybe the D or E or F drive) and select the music files from your computer then copy and paste your music files to this memory card. I presume the music files you need to copy are MP3 or MP4 files.
Nov 06, 2009 | Lexar Professional High-Speed 1GB Secure...
How do i fix my formatting on my lexar mp3
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Nov 03, 2009 | Lexar LDP-200 MP3 Player
I NEED TO FIX THIS
First off, let's talk about the bad news: there are a lot of people who complain about just how picky the Lyra is about which SD cards it can work with. Indeed, the later model Lyra devices on the RCA site itself say "now supports more SD cards" as a feature. Ouch.
Go to a popular memory card vendor like 4AllMemory and you'll find that a search for Lyra-compatible SD cards shows barely a half-dozen matches Lyra-compatible SD Cards
Another issue: Firmware Update 615 you might need to update your firmware to gain better compatibility with various SD cards:targets this specific problem.
While we're listing all the potential problems, it's also worth reporting that there are some reports of Lexar memory cards that require a higher voltage than regular SD cards, meaning that the Lyra either wont start at all, or its battery drains faster than usual.
Comment from the web on this: "Some Lexar memory cards require at least 2.7v to operate. Some Lyra models only use a single AA battery (1.5v). This MAY mean the mp3 player doesn't have enough power to run the card (depends on if RCA used the right parts to temporarily boost the internal voltage to 3v through a booster circuit or capacitors). This may vary between models and even between different releases of the same model. This also may explain why you can hook the device up via usband send/receive files to the card fine but then have problems after you disconnect (a USB wire can provide some amount of power. My previous nexxtech player would actually turn on without a battery when I plugged the usb wire in). "
Generally, you should be hooking your Lyra up to your PC, then running the standard PC disk formatting utility. But even then, here's what RCA warns:
"We have recently discovered an incompatibility with the RD1080/RD1090, windows XP(Service Pack One) and some newer SD cards. We are presently working with microsoftto identify the best approach to correct the issue. Until a solution is implemented, we suggest that you use MMC cards instead of SD. "
To format an external device in Windows XP, just find the device in your "My Computer" window, then right-click on it and choose Format.... You'll see something like this:
windows-format-disk-options.png (since I don't have a Lyra, this shows the default for my second hard drive. Your settings would be similar, but probably a bit smaller!)
RCA offers zero assistance on the best way to format an SD Card for use with the Lyra, as far as I can tell, so I'll say that my expectation is that NTFS will work, you should use a short, letters-only volume label, and you should not choose either "Quick Format" or to "Enable Compression".
When you're ready, click on Start and it should only take a few seconds for the SD card to be ready to roll with your Lyra.
If it works.
please rank if this helps
May 24, 2009 | RCA H100 MP3 Player
Compatibility of sd and sdhc
no this device is SD and MMC only
http://www.amazon.com/iLo-Player-Cherry-MP-556-MP556/dp/B0018ZA2V8
Check your spec, sorry
Regards
Richard.
Apr 01, 2009 | iLO MP3 Player
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Lexar Jumpdrive Data Recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jun 05, 2008 | Lexar JumpDrive MP3 Player
435 people viewed this question
Top Lexar Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
