Question about Nortel Lands Phones
I am unable to unlock my voicemail on my Nortel 7316 phone system
Posted by Kent Fox on
5 Related Answers
ynotphone
ynotphone
  • 192 Answers
SOURCE: is the nortel 7316 analog?
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Posted on Jun 16, 2009
Anonymous
  • 5 Answers
SOURCE: checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Posted on Nov 10, 2009
Anonymous
  • 5 Answers
SOURCE: t7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
ynotphone
ynotphone
  • 192 Answers
SOURCE: T7208 Nortel Norstar phone system - how to
unfortunately when a message is deleted... it is deleted unless you have a back up
Posted on Apr 08, 2010
Ahmed El-Deeb
SOURCE: I have nortel phone system, voicemail is not working at all and feature 981, 983, 985 all say inactive feature--how do I reactive the voicemail??
Dear Annabelle,
Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards;
Ahmed Safaa El-DeebTelecom & Network Engineer
Posted on Apr 11, 2012
I am an end-user of the Nortel T-7316. How can I turn off the tone before the paging or turn off the paging all together. It is very loud and intrusive when on the phone with clients.
I am assuming the page is over your set and not an overhead speaker. The setting is in the configuration programming of your system. Recieve page must be set to 'n' in the programming for your set. If you don't have someone within your company that has access to this programming you may have to call an outside party.
2answers
We have nortel t 7316 i have been locked out of the voicemail admin. i have tried all paswords i can think of but i cannot gt in. i have tried features 983 and than its ask me for login i have tried...
Press Feature 985 - press 9 even when not listed in options. At the password prompt enter 73738767793 and answer the reset password prompt with yes. This will reset the password to default.
We are unable to reset the password to the Nortel BCM50 phone system. We just ordered new 7316 E Nortel phones, but cannot get this feature to work. How do we proceed?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
When I transfer a call from the front desk, the person's voicemail does not pick up, it transfers back to front desk.
Either the voicemail box isn't setup, the voicemail box isn't assigned to that extension, or that extension has forwarding setup that is incorrect. I have no experience with a Nortel phone system though so if you need specifics on how to get into those areas of your system to fix them you'll have to wait for another response.
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
4helpful
Nortel T3716E send calls to voicemail HELP!
Sounds like the call forward no answer isn;t set up on your extension. The first thing to do is to find out what the voice mail pilot number is. That's done by pressing feature 982. The display should say "set:xxx". The set number provided is the voicemail pilot number. Next you'll need to enter system programming. Programming is done on 7310, 7324 and 7316 type sets. Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change call forward no answer on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press theshow key (top right arrow)..
The display should say none. Press the chng key and enter in the voice mail pilot number. press the show key again (top right arrow) To review the rings til forward. Press the chng key if you wish to change the ammount of rings til answered. Press the release key when finished
1helpful
2answers
Cant change time and date on nortel t7208 phone tried the f xx23646 and so on, nothing
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
3helpful
Checking voicemail remotely on nortel T7208 phone
Is the nortel 7316 analog?
T7208 nortel network general voicemail locked
Lands Phones Logo
Top Nortel Lands Phones Experts
k24674
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
