Question about Refrigerators
I just got a grill for fathers day.we put it togetherand found that you packed 4 of the upper hinge or bottom hinge.i need 2 upper and 2 lower.model number is cg2240501-kf/cg2240506-kf
Posted by Linda Smith on
David Del Polito
    Habit-Forming:
    New Friend:
  • 44 Answers
Call the manufacturer with the information and they will send you the correct parts.
Usually for free being it's brand new.
parts 888-837-1380 8-5 pst
Home Depot- Lone Star Charcoal Grill
Posted on Jun 20, 2019
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: Sunbeam Outdated Parts
I guess you will have to make or get mone made up for you. You will not I venture be able to get one off the shelf.
Posted on Sep 09, 2007
Anonymous
  • 3 Answers
SOURCE: I need upper track (plastic
I have a Graco 4 in 1 Ultra Sleep System Model 4600 CL. There is a recall on this model for the track guides breaking. The website is www.simplicityforchildren.com You can get a replacement track system for free and you can also order parts at 1-800-858-8323.
I also have the complete instructions for assembly of the crib, toddler bed and day bed.
Posted on Aug 02, 2008
JSEhandyman
Jon Stignani
  • 368 Answers
SOURCE: Need replacement grill plates for a George Foreman GRP4P indoor grill
Hi joea64,
I'd contact the manufacturer (Salton, Inc.) customer service site for parts or manual. If they don't have them, they should know where to send you (though if they don't, I'd seriously wonder about the company).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 31, 2008
Anonymous
  • 24 Answers
SOURCE: DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Posted on Jul 25, 2009
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: 1997 Jetta GLX VR6 giving
pull the multi plug connectors off the coil pack and check the connections ,and then rub the pins with a soft lead pencil and see what happens
Posted on Dec 12, 2010
How to remove door pins on a 2003 tahoe
take to a bodyshop as will need special tools , i just wonder why you would want to do this , don't try using a drift as will cause damage to hinges
Mar 13, 2015 | 2003 Chevrolet Tahoe
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
How to replace cooling fan on peugeot 206
The cooling fan on the peugeot 206 is situated between the front grille and ththe radiator, To gail access to the fan you first need to remove the 4 push/pin fixings that hold the upper grille panel ,then remove the 2 torx screws from either end of the upper panel (one at each end. Next the lower grille panel needs to be removed by disengaging each end from just below the headlights, these ends are held in place by clips ,and care must be taken when pulling the lower grill from these clips.Once you have both upper and liwer grille removed ,it a simple matter of unplugging the fan connector ,and removing the 3 fixing bolts , the fan can then be removed ,
Apr 02, 2012 | Cars & Trucks
How to put in a upper door hinge pin
Put a jack under the door with a piece of 2x4, as close to the middle as you can. Jack up the door, watching the hinge pin until pin is in the center of the movement range. Put a long metal rod or socket extension on the bottom of the pin and tap out with a hammer. Use same rod to remove bronze - alloy bushing. Tap new bushing in and use a 16 penny nail to check alignment of holes in hinge to bushing, raise or lower jack to center. Tap in new hinge pin. Release jack and check door for alignment on latchpin - If low, jack up door to relieve pressure, loosen upper / lower hinge bolts, raise door with jack approximately 1/8 inch, retighten bolts, remove jack and test Repeat procedure until pin strikes the center of the latch..
Nov 10, 2010 | 1991 Ford Explorer
I have a 4 in 1 food network grill station and ned the instructions manual. I also need to find out how to order the handle which is broken.
my 4 in 1 grill one of the grills is stuck because someone put the lower grill on the upper part I can't get it off help I am dying for a panini!
May 31, 2010 | Kitchen Appliances - Others
How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
Bottom door hinge replacement easiest way?
Hinge, Door Removal and Installation
  1. NOTE: A second person is required if the Flexi-Work Table 156-00070 is not available.
    Support the front door (20124) using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) and front door lower hinge on the front door and body.
  1. Remove the front door hinge-to-body retaining bolts.
  1. Remove the front door hinge-to-door retaining bolts and remove the front door upper hinge and front door lower hinge.
  1. To install, position the front door upper hinge and front door lower hinge to the front door and body. Install the retaining bolts. Tighten to 25-35 Nm (18-26 lb-ft).
  1. Adjust the front door and front door upper hinge and front door lower hinge as outlined, and remove the support.
Jul 01, 2009 | 1995 Ford Thunderbird
Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Frigidaire PLMV169DC Microwave Oven
Replacement of keyboard on a hp ze 5000 laptop
My buddy and i put together a video a while ago for this you can find it here
This is not your model but the concept is the same.
Disclaimer: careful bad things can happen, not responsible etc etc :)
good luck and tell me how it goes, please don't forget to rate.
Nov 13, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
