SOURCE: RCA D52W26 Screen problem
remove spkr grill and a few screws, unplug connectors,remove entire screen assy and clean....reassemble
SOURCE: I need the Durabrand phone number
You need to contact Funai customer support, that produces durabrand.
Here is the contact form: Contact Funai Customer Support.
By phone you can call Durabrand Products 800-242-7158 in US, add 001 if calling from outside USA.
SOURCE: Fuzzy pic on Dynex 32 LCD TV
I am sumising that you have checked the menu controls on your tv and are recieving your signal from the cable box , so therefore if it is not comong from the Aerial and direct from the cable company then the picture should be clear .. However sometimes people dont check to see if the signal is RGB or composite from the box RGB is usually best if you have a scart socket connection or SVHS if your set has that capability .. sometimes people have an old VHs recorder and the sinal is coming from that to the set through the Aerail fly lead if it is you will probably find they are conflicting giving you a poor picture retune your Video to another channel instructions should be in its manuel if not come back to me ... reagrds Vortash
SOURCE: Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get
an external battery charger and charge battery separate from
phone.Another battery and charger will set you back about 10 dollars on
ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
