Question about Radio Communications
How do I get my Bluetooth sounding headphones to pair with my phone
Posted by Dana Woodward on
5 Related Answers
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: Pairing bluetooth headphone and mp3 player
search for devices option and visibility!! plz rate this post
Posted on Aug 25, 2008
lukem9962
luke m
  • 144 Answers
SOURCE: no sound through headphones
the pop port on your phone may be dirty or broken
Posted on Apr 01, 2009
Anonymous
  • 3 Answers
SOURCE: Can't pair bluetooth headphones with Insignia Pilot MP3 player
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
Posted on May 31, 2009
Anonymous
SOURCE: Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Posted on Aug 19, 2009
Chris McWethy
  • 170 Answers
SOURCE: How do I pair insignia bluetooth headphone with
The Insignia headphones must be set to "pair".
With the headphones off, press and hold the power button on the headphones until the logo starts blinking red/blue. You are now in "pair mode". Have your Touch look for bluetooth devices and it should see it now.
Hope this helps!
Posted on Apr 14, 2010
How to use bluetooth wireless headphone with alcatel smart phone?
There are a lot of alcatel phones. Do you have a model number? Basically, you go into the menu or settings, find the bluetooth menu and press "pair". Press and hold the power button on the bluetooth headphone until it "beeps".
The phone will ask for a pairing code, typically 0000. Try this or get me a model number of both the phone and bluetooth. Good luck!
Jun 11, 2017 | Alcatel Radio Communications
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How do I pair my phone and iPod at the same time?
I don't think you can pair two devices at the same time. You will have to pair one at a time . On the phone go to connections and bluetooth , switch bluetooth on and make sure it is visible. Press scan for devices .your headphones should be shown in list if they are set to visable .press pair and a option to put in a 4 digit code willcome up type in a code and put same code in the headphones and press pair these devices. Do the same with the ipod but type in a different code and put code for ipod in headphones pair devices . You should be able to listen to either one
Jan 21, 2015 | Cell Phones
My headphones wont work on my laptop
Because you use the word 'pair' I have to assume that your headphones are Bluetooth-enabled. If this is the case, you can pair and connect the headphones to your phone and/or your iPad, which are, like most, if not all, phones and tablets, Bluetooth-enabled. On the other hand, very few desktop computers and/or laptops are Bluetooth-enabled. Your computer does not recognize your Bluetooth-enabled headphones because it is not Bluetooth-enabled.
Dec 26, 2014 | Audio Players & Recorders
I did pair the turtle beach head set stealth 500 but when I turned off the power then turned it back on it won't pair with thePlaystation 4 system .?
what did you pair it with the first time? the ps4? if you pair it with one device and then want to pair it with different one, you need to either turn off the first one, which will make the headphone search for another signal or, there should be a bluetooth button on your earphones. this also makes it search for another bluetooth signal.
for example, i use my bose bluetooth speaker for my phone and my laptop. when it's paired with my laptop and i want to switch it to my phone, i have to turn on bluetooth on my phone, press the bluetooth button on my speaker and then it connects to my phone.
Nov 09, 2014 | Audio Players & Recorders
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
How do i connect my backbeat 903 to my phone
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics web site)
Apr 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
How to pair a Motorola D200 to a phone??
You will never be able to pair the d200 to a phone or another device, for this is a a2dp bluetooth dongle, that´s why it works with your headphones.
Mar 07, 2008 | Motorola Lands Phones
Pin code
Is this the first time you are pairing two Bletooth devices ? Is the security pin for your Samsung phone '0000' ? Usually, the code you have to enter on your phone to pair it with a Bluetooth headset or headphones is '0000' (the number 'zero' 4 times), unless Jensen's Bluetooth headphones use a different pin.
Hope this helps.
[email protected]
Dec 22, 2007 | Audiovox WBT212 Headphones
Radio Communications Logo
127 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
