Question about Medical
How long will it take to rec over after a hysteroscopy
Posted by Marlene Lottering on
  • Akhil Antony
    Akhil Antony Jun 20, 2019
    1 Day
  • Diane Fletcher
    Diane Fletcher Sep 08, 2019
    Depends on your health you will feel some discomfort for a few days this should get easier.
Joyce Coleman
    Sergeant:
    Habit-Forming:
  • 79 Answers
These symptoms usually go away in 1 or 2 days. If the doctor filled your u t e r u s with liquid during the process, you may have watery v a g i n a l discharge for a few days. Many women are able to return to work on the day after the procedure. But it depends on what was done during the procedure and the type of work you do. https://www.alldaygeneric.com/product-category/womens-health
Posted on Aug 05, 2019
john h
    Top Expert:
  • 23,424 Answers
Ask your doctor
Posted on Jun 18, 2019
I had IUD removed through hysteroscopy in April 2017 after removal i never recieved my menstrualcycle again.im not pregnant
Please contact a physician or clinic.
If you need assistance,please contact a trusted friend or close relative.
FIXYA is not a provider of medicine or medical care.
Mar 08, 2018 | Health & Beauty
Blood pressure 51/99 after hysteroscopy for 48 year old female
I wouldn't think so, I'd love it if mine were that low. You might check with your doctor's nurse just to be sure.
Mar 04, 2015 | Exercise & Fitness
I am a casio fx-82MS user. i would like to know how i can convert polar form to rectangular form in my calculator
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Nov 13, 2010 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
I made a video store program that lets users rent movies. I am having trouble with trying to get an list of movies from my database to show into a combo box. The only thing the combo box should show is...
yourCombo.Clear
Do While Not rec.EOF
strRetVal = rec.Fields("title").Value & ""
yourCombo.AddItem strRetVal
rec.MoveNext
Loop
"rec" is your recordset containing the list of titles from the database.
Apr 03, 2009 | Microsoft Visual Basic 6.0 (361-00686) for...
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Rec Inhibit Light remains ON
The easiest way I know to fix the problem is just play tapes. Sounds like a bad switch contacts. clean the contacts or replace the switch. I don't know of any shortcuts. Sorry
Apr 16, 2008 | Sony PVW-2800 VCR
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Recording Problems!
You may try a different style DVD disc. Are you using (+), (-), or (RW) the DVD makes a difference. http://pdf.crse.com/manuals/2636511113.pdf Here is the manual for your product. Check pages 9 and 10. These pages tell you the type of DVD disc to use, and what speed they can be used. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Medical Logo
217 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
