I can't find anything on an RT 254, but if you meant RT
524, that is a rear tine tiller with a 5 horsepower gasoline (petrol) engine. That engine should not require you to add oil to the petrol. You can purchase a generic service manual which does includeyour tiller
here if you like.
Or, just look for a crankcase oil drain plug which sticks out the side of the very base of the engine, and a fill plug, which is angled and higher up and usually plugged with a screw-in plastic plug. Take that plastic plug out and check the oil - in fact, if it's an old machine, I recommend you drain the oil (using the lower plug) and refill it (until it is at the level of the upper plug). In any case, this confirms you don't need to add oil to the petrol. Happy tilling! Please rate my solution if helpful, thanks.
