Question about HTC Touch Diamond Smartphone
On the front of the screen, once is open the phone, some numbers in red appear and does not start the phone
Posted by alessandroar on
Anonymous
  • 4 Answers
Dont worry it just boot the device for few seconds...then main scrren of windows appear...if phone does not start at that time u just format u r memory card in computer and try it.
Posted on Aug 09, 2009
My son said he added a folder to his 8330 blackberry curve and now all the icons on the front screen and all other screens have dissappeared. I am clueless on what he did. He can still make and recieve...
From the home screen where the icons used to be, press the BB menu butoon, then select Show all and press the Pearl Button.
If that does not work, then download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 11, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Do i need an activ Sim Card, and internet active to unlock my BlackBarry 8800 series
Not necessary ...to unlock the device get the network unlock code from service provider, call them and tell them you want to unlock your phone because you are going overseas if they ask, but they won't and they will unlock it for you. They will send you the code to do it. here is the way you can unlock the 8800, which I used for my phone. Just get the code from service provider 1. Press the Menu key 2. Scroll to and select Manage Connections. Select Turn All Connections Off. 3. Press the red end key or the Escape key to go back to the Home screen. 4. Scroll to and select the Options icon. 5. Scroll to and select Advanced Options. 6. Scroll to and select SIM Card. 7. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device. 8. Type MEP then hold ?ALT? key and type number 2. Note: When typing in MEP ATL 2 the letters/number will not appear on the screen, this step open up the ?Enter Network MEP? box. 9. Enter the unlock code. 10. Press the trackball (?Code Accepted should display) 11. Press and hold the red End key to turn the hand held off and then back on. 12. Once the device has powered on, follow steps 1 & 2 and restore connections.
Oct 31, 2009 | RIM BlackBerry 8800
How to unlock bb 8800 t-mobile
Follow the instructions mentioned by marbleann & get the code from unlock4u
Jun 07, 2009 | RIM BlackBerry 8800
The number 9 button on my N95 is behaving like the red button.
You either have a bad Flex Cable or Minor water damage under the keypad. It needs to be opened and inspected. If you are a little handy, the N95 is not that difficult to open. Search youtube for a opening video of the N95 and inspect the flex cable and its endings then under the keypad itself for signs of corrosion
Mar 26, 2009 | Nokia N95 Cellular Phone
I can't turn off my Samsung SGH - D880
Yesterday I also got the same problem on Samsung DUOS SGH-D780!
I found temporary solution how to drop this error message and run the phone normally, but after next reboot it often become again. I will ask Samsung tech. support about this, but now here is the emergency solution:
1. Turn OFF the phone (by removing the battery)
2. Move out all the SIM cards from the phone
3. Insert the battery again (BUT DON'T TURN ON THE PHONE, just insert the battery)
4. Insert a charging cable into the phone and insert the adapter in wall outlet
(then I see the loading screen for the short time and after that CHARGING icon appears)
5. After that turn ON the phone. It will start in no-sim mode.
6. Turn OFF the phone
7. Remove battery, insert SIM-cards, insert the battery.
8. Turn ON the phone
After that it gonna be work good until next reloading...
Feb 27, 2009 | Samsung D880 Cellular Phone
I need solution for start up failed contact retailer
type code *#7780# on the display screen message appear restart your phone original settings then ask for code default code is 12345 .your phone restarted and all data on your phone erase
second method first of ur cell phone then press on button answer key or red button then 3 then * press these buttons at once for few seconds and then leave it and ur phone start formatting
Feb 23, 2009 | Nokia 3230
We have a problem putting in names and addresses.
All tomtoms are more or less the same. You tap the screen to make selections.
Switch on , let it boot up / Tap the screen / Then tap " Navigate to" / then tap "address" / Then tap either "City centre" or " Street and House Number , or Postcode " ( you select one of these by tapping screen ) . Lets say you just tapped "Postcode" . A keypad will appear on the screen for you to enter a postcode. NOW, enter the postcode ... as you enter the postcode , streetnames will appear and you can either continue to enter the postcode OR you can choose one of the street names that appear. Once you have done this , the tomtom will ask you to select a "house number" . if you don't know the number then just 'try' selecting number 1 . Once you have done this , select "Done" and the tomtom will switch for that screen to the "route calculation screen" . if you now tap the screen once more your tomtom will start giving you direction both visual and audible , to your destination . ( you must begin to move before it will start ) . ....................... Once you have completed the journey , you can now cancel the navigation by once again tapping the screen , then use the "right arrow icon" to move through the menue screens. When you see an icon with a RED CROSS through it , and underneath it says " clear route" , select that by tapping and the route / navigation will be cleared. ... Good luck , hope this helps.
Nov 27, 2008 | Tomtom One XL GPS Receiver
Unlock Code for Sidekick II Juicy Couture
How to Enter Unlock Codes on T-Mobile
  1. Press the Menu key.
  3. Select Turn All Connections Off.
  4. Press the red end key or the Escape key to go back to the Home screen
  5. Scroll to and select the Options icon.
  6. Scroll to and select Advanced Options.
  7. Scroll to and select SIM Card.
  8. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
  9. Hold down the Alt key and type in MEP2. Note: When typing in MEP2 the letters/number will not appear on the screen. This Step opens up the Enter Network MEP code box.
  10. Enter the unlock code.
  11. Press the trackball (code accepted should display).
  12. Press and hold the red End key to turn the handheld off and then back on.
  13. Once the device has powered on, follow steps 1 & 2 and select Restore Connections.
Dec 08, 2007 | T-Mobile Sidekick II
Phone keypad keeps freezing and dialing random numbers
remove the battry and open the fon and put it under sunlight and clean the key ped circuit with the earaser
Nov 28, 2007 | Motorola Mobility L6 Cellular Phone
HTC Touch Diamond Smartphone Logo
63 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
