This set had a convergence problem where a diode on the separate power board causes the convergence to be way out. Also if it has the "Guide Plus" you may be missing items in the main menu-----in the guide menu set it so you show you have no cable box, no vcr, and set the zip code for 99999----if this has been helpful please indicate with a vote for me.
If the diode is bad---it should be an easy fix for almost any technician who comes to your home.
This is called vertical pincushion IMHO.
With a bit of luck you should be able to adjust this from the service menu.
Access the service mode: set SLEEP TIMER to 0 MIN.
While this is still displayed, simultaneously push DISPLAY and
VIDEO STATUS.
