Question about Medical
A pair of hands from under my bed was trgying to pull me out of bed.husband says i was screaming and wouldnt open my eyes
Posted by Majidah Fortuin on
john h
    Top Expert:
  • 23,424 Answers
Notify doctor to check your meds
Posted on Jun 18, 2019
Andrew Taylor
    Top Expert:
  • 33,395 Answers
Sleep terrors are episodes of screaming, intense fear and flailing while still asleep. Also known as night terrors, sleep terrors often are paired with sleepwalking. Like sleepwalking, sleep terrors are considered a parasomnia - an undesired occurrence during sleep.Mar 9, 2018
Sleep terrors (night terrors) - Symptoms and causes - Mayo Clinic
https://www.mayoclinic.org/diseases-conditions/sleep-terrors/symptoms.../syc-20353524
videos
https://www.google.com/search?q=night+terrors
Posted on Jun 17, 2019
Tip
Tips for Threading your Needle
It's my experience that the automatic needle threaders on most machines work fine for a while, then the little hook that pulls the thread through the eye of the needle gets bent so it won't go in the eye anymore.
Here are a few tips that will help threading your needle the old-fashioned way easier:
1. Use a pair of tweezers. I have a large pair of tweezers that live on my sewing table. They are great for pulling out threads I've ripped out, for helping guide fabric under the pressure foot, and for threading the needle. I hold the thread in the tweezers maybe 1/2" or less from the end of thread, and it just slides on through.
2. Instead of,or in addition to, wetting the end of the thread, wet the eye of the needle. (I lick my index finger and wipe the eye with it.) For some reason, the moisture in the eye sort of pulls the thread in.
3. Make sure the thread ends with a sharp cut. Snip off the end if it's the least bit raveled or frayed.
4. Use plenty of light. The little lights on most sewing machines are really pretty pathetic, so don't depend on that for your only light source, especially when threading your needle. I have a clamp-on light, a floor lamp, and two table lamps on when I'm sewing--and that isn't enough, sometimes!
5. Get a pair of reading glasses. They magnify small things--like the eye of a sewing machine needle!
Hope these tips help!!! Happy Sewing to you all,
Robbie
on Feb 22, 2010 | Sewing Machines
How to open boot for mercedes c200 on a 1998
where the steering wheel is if its a right hand drive you have the release for the hand break its just under that a red handle thats if it hasent been snaped off if so the wire will still be there get a pair of pliers and pull it same as my 1994 c180
Sep 26, 2012 | Cars & Trucks
I replaced a broken Hansgrohe hand shower with a new Hansgrohe Clubmaster 3 - now have very poor water pressure - how to correct?
Hi Christieb942,
When you get a new hand shower you can sometimes get sediment on the federally mandated FLOW RESTRICTOR. Not screaming, that is ****** in cheek. To CHECK the Flow Restrictor for debris, look at the hose connection end of the hand shower. You will see an INSERTED part that is green, yellow, or white. We have to push that in there to satisfy the EPA requirement for flow. You can pull it OUT and rinse it off. Then connect your handshower and try it and see if it is improved. You will not void the warranty in any way by doing this. I hope you understand what I am telling you, but if not you can call me 800-334-0455. I wish I could answer more directly, but Big Brother has eyes.
Sep 18, 2011 | Hansgrohe Model 28525: Clubmaster Oil...
How can you open a stuck hood on a 98 mountaineer?
If you have not got it by now there is a "CaveMan Method" to this problem. Have someone pull the release for you at the same time pound on the hood above the latch. If that does not work remove the release from under the dash. Take a pair of Vise grips and pull the cable and pound (with your hand).this should get it open.
Sep 13, 2010 | 1998 Mercury Mountaineer
Tailgate won't open
you will probably need to remove gate panel on bed side and unlock by pulling actuating rod by hand inside gate.
Apr 25, 2010 | 1999 Chevrolet Silverado 1500
95 jetta whistling/screaming sound
Plural husbands? Check each wheel by jacking up that corner of the car and spin each wheel by hand. If one of more of the wheels makes this sound, there may be an incorrectly installed pad in the brake assembly which could be dragging on the rotor. Make sure that each caliper will retract properly. Hope this helps!
Apr 03, 2010 | 1995 Volkswagen Jetta
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
We have a 'Little Tikes Hide and Slide' and we need to take it apart. How do we do this (without breaking it)?
The key is the red locks on each side of the climber wall. Be careful not to force the red locks open because it WILL cause them to tear on the seam.
I used two big flat screwdrivers and another pair of strong hands. What I did was I inserted the screwdrivers in between the outer part of the red lock and the yellow wall, leaving just enough gap between the screwdrivers for a hand to slide in. Then pushed the screwdrivers outward as lever to loosen up the lock. Then my husband finished the job by inserting his hands between the gap created by the screwdrivers and pull.
I hope this is helpful for you, as I know I'm better in demonstrating than describing.
Jul 10, 2009 | Little Tikes Toys
Medical Logo
196 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Are you a Medical Expert? Answer questions, earn points and help others
