Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
The volume does not work
I putmy ipod on the bose system, it plays but the volume does not work?
Posted by ani1112 on
Anonymous
    Problem Solver:
  • 7 Answers
Try turning the volume up on the bose system
Posted on Aug 08, 2009
Ipod charges on bose dock but won't play ipod firmware 3.1.2 recently updated
i have bought a ipod nano and i want it to work in my car stereo it charges but does not play it does play my sons ipod touch so the cable is ok
Feb 07, 2010 | Bose SoundDock digital music system...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Bose sounddock remote and ipod menu functions
Unfortunately I've never seen a universal remote that will control the extra functions of this. If it's the original SoundDock, you can only do: volume, power, play/pause, skip/scan. If this is a SoundDock II or SoundDock Portable, you can only control: volume, power, play/pause, skip/scan, and playlist up/ playlist down. Quite honestly, that's all I need to do on my SoundDock. I can't really read what's on my iPod from where I'm sitting in the first place. It may be possible to use a universal learning remote for this, but you'd have to teach commands from an apple remote as well as the bose remote, and the learning remote (+apple remote) may cost you over 1/3 the cost of the SoundDock. It also may not work perfectly. I hope this helps somewhat.
Jun 22, 2009 | Bose SoundDock Digital Music System for...
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
Bose docking station problem. Remote will not work on either my ipod touch or I Phone. The volume buttons work on the remote but the skip and pause/play buttons do not. The Bose is brand new and straight...
If it is brand new. It is under warranty. Go back to the store where it was purchased and tell them the problem. They should replace it with another new one. Have them show you how to use it on all of the functions on your Bose Docking Station. Make sure you tell them about the ipod Touch and the iPhone.
Jun 07, 2009 | Bose SoundDock digital music system...
Volume stays low won't increase
Your volume limit on your ipod is probably set low. To check it, go all of the way to the ipod's main menu and go to settings. Then go to volume limit and put it where you would like it to be if it is too low. Then go back to your music and play it. Turn the volume up to your liking and it should work and play louder.
Apr 06, 2009 | Apple iPod MA446LL/A MP3 Player
My iopd won't change songs when playing on the bose
Reset your Ipod. Go online to troubleshoot your ipod. I had the same problem and resetting the ipod fixed it.
Dec 25, 2008 | Bose SoundDock digital music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
587 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
