Question about SanDisk Sansa e270 MP3 Player
Wont let me transfer songs n it doeesnt show up on my computer
When i try to connect my sandisk it wont let me transfer songs on or delete songs pleasee !!!! help fast
It seems you will have to reformat the device.
on "my computer" right click reformat on the sansa
this will however remove everything from the device
Posted on Aug 17, 2009
6ya staff
SOURCE:
I got a problem with my mp3
Transfers onto the m240 can be done in 2 USB connection modes:
MTP mode: Media Transfer Protocol using software, e.g. Windows Media Player 10 or higher.
MSC mode: Mass Storage Class using Windows Explorer, looking in "My Computer" viewing the player as a removable disk.
Typically, songs put onto the player in MSC mode can not be viewed in MTP mode and the other way around.
Switching to MSC mode in the player's menu:
Look in the player under Settings Menus > USB > select MSC for using the "copy and paste" or "drag and drop" method for transfers in "My Computer".
When Auto Detect is selected, it depends on the configuration of the computer, what setup for priority has been installed.
Forcing the player into MSC mode:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Information for the USB connection mode and how to make hidden files in XP and Vista visible, on the support site:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for the m200 series players (readable with Adobe Reader):
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Don't hesitate to add a comment.
Apr 15, 2010 | SanDisk Sansa m240 MP3 Player
SanDisk freezes when trying to play a song, then it restarts itself.
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works.........Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier.....
Then disconnect from your computer and see if it worked
Hope it does..........Please rate
May 17, 2009 | SanDisk Sansa e260 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
Deleting unwanted songs
The Sansa M200 series devices do not allow deletion of downloaded content directly from the device. You must connect he device to PC/Mac via USB to delete downloaded content. You will also need to use media software such as Windows Media Player, Rhapsody, iTunes, etc.. to see all of the music content on the player to be able to delete the songs you don't want. (i.e. just viewing the device in Windows Explorer might not show everything that is on he player.)
Jan 05, 2009 | SanDisk Sansa m240 MP3 Player
Some songs i added into it won't show up in player
Delete all the songs on your device and transfer them back..You could have a corruption in your databasse...
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
Thank you
Computerrep
Dec 22, 2008 | SanDisk Sansa e260 MP3 Player
Files transferring to sansa e260
Try to delete all the songs you have on your device and if that doesnt work just format it..
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Sep 01, 2008 | SanDisk Sansa e260 MP3 Player
Deleting songs from my sandisk mp3 player
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer1.gif, go to media, music and delete them from there.
Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
Thank You
Computerrep
Mar 21, 2008 | SanDisk Sansa m230 MP3 Player
Sandisk sansa m240 mp3 player
You can connect the device to your computer and manage it thru "My Computer. Open My Computer, then open the device (i.e. Sansa m240). Inside there is a Music folder, you can delete them from here. You can also drag songs here to transfer to the player. If you are not able to see the "music" folder, you may need to enable "Hidden Files and Folders" on your computer. Best of Luck.
Sep 06, 2007 | SanDisk Sansa m240 MP3 Player
Can't delete songs
Try changing the "mode" on the device. Settings>Mode or USB Mode>MTP or MSC.* *(if you have thr 'R' version, your options will be Rhapsody or Plays for Sure) If you transferred music in one mode, you are not able to see it in the other mode. Best of Luck.
Sep 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Joe Negus
Joe Negus
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
