Question about Brother DCP-7030 Digital All-in-One Laser Printer
Md# MFC-440CN. when useing the auto feed black line full length of paper
Posted by rstudyvin on
Leroy Elliott
    President:
  • 3,085 Answers
Open the document feeder and clean the scanner glass
Posted on Aug 08, 2009
Lines appearing down center of copies when loaded through auto feed
Check out our tip for this problem:
http://www.fixya.com/support/r3639811-black_lines_faxes_or_copies
I hope this helps, if so please rate our solution.
BuddyMc
May 09, 2011 | Brother MultiFunction Center MFC-440CN...
When I scan a document, a black line the length of the page is seen on my scanned copy. What is causing this? I have cleaned the print head.
When you are scanning with the auto paper feed, if the scanning window has a spec on it, you get a line the lenght of the paper.
Feb 17, 2010 | Brother MFC-685cw InkJet Printer
When printing lines are running through the sentences.I have a brother mfc440cn printer
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
I cannot easily remove the paper drawer from my MFC-440CN printer. I must yank it out which surely must be damaging to the printer. It usually takes about a dozen yanks to free it so I can load more paper....
Hi Ed, that's a common problem, you just need a tiny dab of vaseline on the inside right hand corner on the top edge of the paper tray. There's a ramp there that lifts up the feed roller when you insert the paper tray.
Dec 03, 2009 | Brother MultiFunction Center MFC-440CN...
Brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Sep 04, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC 440CN pick up wheels only work about
take q tip and dip in alcohol with printer off clean paper wheels let dry completely. Your printer should be okay then. Make sure you do not drip any alcohol inside the printer and that the printer is off and unplugged.
Jul 11, 2009 | Brother MultiFunction Center MFC-440CN...
My Brother MFC-440CN won't feed paper.
Must be the clutch that's shot, if cleaning the rollers didn't work
Apr 25, 2009 | Brother MultiFunction Center MFC-440CN...
Paper jam message brother MFC-440CN
Generally theres still a small piece stuck somewhere. Remove the back where the paper feeds through and check there. Then open the top so you can see the ink head and check around there. That should do it. The printer sometimes wont remove the jam until you open that top lid.
Also try switching it on and off again just to be sure.
If it's still there, the only other way is ripping it apart to find that pesky bit of paper still stuck.
Mar 24, 2009 | Brother MultiFunction Center MFC-440CN...
No paper feed (brother MCF-440CN)
Had a similar problem with the MFC-885cw. Turns out that , if you have a photo paper tray installed which sits just above the main tray, you need to puill it all the way back towards you otherwise it blocks the paper feed. Not the best design feature I've ever seen.
Feb 20, 2009 | Brother MFC-440CN InkJet Printer
MFC 440CN fax machine
Is this through the ADF (top feeder) or from the paper tray? Either one can have some build-up on the paper feed rollers and would have to be cleaned.
Jan 08, 2008 | Brother MultiFunction Center MFC-440CN...
Brother DCP-7030 Digital All-in-One Laser Printer Logo
82 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
