SOURCE: locked keypad
Try the last four digits of your phone's number, then 0000, 1234, etc...
Did you reset the PIN yourself, or is it the default PIN? If you didn't change it yourself the above mentioned will probably unlock it, if not, you may have to take it into a service providers Corporate location and have a Tech. unlock it.
Good luck.
SOURCE: daughter messed around with settings put in pin
The pin code is for the SIM-card
Contact your service provider for PUK-code.
This is your solution! Please remember to vote!
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: ive bought a samsung galaxy
You can get the SIM network unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
SOURCE: apn settings
I have a S4, not sure if its the same but here's what i do to get to APN settings:
First go to settings and tap on the connections tab at the top of the screen. Then tap on "More networks" under the "network connections" subsection. Once there you should see a button for "mobile networks". tap on it and it should bring you to another screen with a button called "Access Point Names (AKA APN). Tap on that and you're there!
Like I said, this is for a Galaxy S4 but I think it would be a similar if not identical procedure for the S3. Hope this helps :)
